View Poll Results: fix it? or start over?
screw it, some dynamite should finish the rest and a new rear is in order 11 78.57%
get some good used pieces and cobble it back together 3 21.43%
Voters: 14. You may not vote on this poll
Old 10-05-2011, 05:52 PM   #1
INSIDIOUS '86
INSIDIOUS '86's Avatar
Exclamation HELP! identify the scatterd pieces
I know one is a spider gear how about the others? off my buddys truck and we are wondering if humpty dumpty can be put back together again?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-05-2011, 07:04 PM   #2
J Knight
J Knight's Avatar
Re: HELP! identify the scatterd pieces
If you have a stock rear end now and dont know how to set the backlash yourself and have to take it to a shop, it would be cheaper to find a used rear and swap the whole thing out.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 10-05-2011, 07:18 PM   #3
hatzie
Moderator
hatzie's Avatar
That doesn't look good at all.
hatzie is online now   Reply With Quote
Old 10-05-2011, 08:10 PM   #4
78 Chevyrado
Get a whole new rear from the junkyard. itll take pulling the covers off a few to find the one you want that isnt damaged and/or has the ratio you want. i got my last one for approx $45 for a 12 bolt. one note, van rears DONT fit, whatever you buy has to come from a squarebody, 73-87.
if the pieces of metal got into everything else, the only part of that thing that is still good is the case itself (maybe) and the maybe the carrier (not the gears, just the carrier).
78 Chevyrado is offline   Reply With Quote
Old 10-05-2011, 09:00 PM   #5
79k30dually
The biggest problem in the puzzle is the round shaft, it's hardened steel. The force required to break this peice is hard to imagine. The housing is probably screwed. Without jigs and alot of money it's cheaper to replacing the assembly. Good luck, Ron..
79k30dually is offline   Reply With Quote
Old 10-06-2011, 10:31 AM   #6
INSIDIOUS '86
the transmission is a stage 3 comp trans from patc and the 1-2 chirps the tires everytime, and theyre 245's, so i think after a couple months of that constant shift shock the worn rear end let a piece loose and it jammed the ring and pinion going down the road at 45mph. truck had 3.08
so we are thinking maybe an 88-98 rear diff would have more chance of being a posi i know you have to re weld spring/shock hangers but it should just bolt in and go after that right?
Old 10-06-2011, 10:42 AM   #7
silvereagle07
silvereagle07's Avatar
Yes it will bolt in after you move the spring perches but the 88-98 rear end is just a bit wider I believe. 1/2 inch or so, it will push your tires closer to the lip of the rear fender. Which looks better in my opinion but you will have to check your wheel clearance.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 10-06-2011, 02:52 PM   #8
f.monroe
f.monroe's Avatar
Looks like what is left of a Gov-Loc rear carrier. They are known for doing that . Mine shot pieces through the rear cover when it came apart back in the day. I have never had another with the Gov-Loc setup.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 10-06-2011, 05:09 PM   #9
INSIDIOUS '86
so how do i tell if its a gov loc vs conventional posi?
