Old 10-06-2011, 04:15 AM   #1
JRBECK64
Gen 2 Chevy Heads and Vintage Air?
I am wanting to install Vintage Air on the 67 but the early heads dont have any holes in them where the normal aftermarket brackets attach. Can someone who has already dealt with this show some pictures and bracket applications for this problem? I know the alternator either has to go low on the passenger side or to the top on the Drivers Side but without the mounting holes im not sure how to do this. Thanks for any help you can give with this.
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 10-06-2011, 10:40 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Gen 2 Chevy Heads and Vintage Air?
I would check with "Vintage air" they probably have designed a bracket to work with your application that uses bolt holes that exist.There are also other vendors for A/c surely some have dealt with this.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-06-2011, 03:35 PM   #3
big mike71
big mike71's Avatar
Dumb question, But are gen 2 heads the same as vortec? If they are I'll take a pic of mine.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 10-06-2011, 09:10 PM   #4
JRBECK64
big mike71,
No I dont think they are (The Heads). What I did find out today after talking with the guys from Vintage Air is that the Brakets for the AC and the Alternator are part of the $1350 Kit. I guess the brackets actually mount to the front of the Water Pump and the Compressor and the Alternator set up high and in the middle instead of to the outboard of the Valve Covers. Looks a little goofy to me but I have a football field under the hood to work with so I guess it doesn't matter unless my Water pump goes bad then I will have to take the front of the engine off to change it. I guess there will always be a little bad with the good. I sure wont be complaining on a hot summer day. The guys from Vintage Air said they can just about provide any setup you want and can accomidate you as long as you let them know before they send the kit to you.
JRBECK64
Old 10-06-2011, 09:15 PM   #5
vectorit
What?
vectorit's Avatar
The kits I have been noticing, since I am thinking about putting in a AC system on '70. The compressor is mounted with a supplied bracket, that looks like it uses 2 bolts from ram exhaust manifold bolts.
Compressor on the passenger side low, and the alternator on driver side stock.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
