10-03-2011, 03:19 PM | #1 |
1962 Chevy C20 Lift?
I just picked up a couple of '62 C20's, to make one good driver. i understand it has torsion bar suspension in the front. My question is this; can I lift this truck about 3 to 5 inches, and how? Thanks in advance!
10-07-2011, 05:03 PM | #2 |
Re: 1962 Chevy C20 Lift?
Sorry no one piped in. You can lift buy cranking up the bars but the ride is going to get stiffer, a lot stiffer depending on how high you lift it. My brother did that to his 62 1/2 ton and it was very harsh.
If your going to do it, make sure you lube and oil screw and block assy. 50 years of crud will strip the bolts.
1961 GMC. Start date 1/20/2011 Past projects: 1958 Fleetliner 14ft Runabout 1966 Caprice 2dr 1970 VW Squareback |
