Old 09-30-2011, 03:34 AM   #1
doctrouble
doctrouble's Avatar
First Drive
Went and got it registered and insured today. Got to it and the frellin thing wouldn't even start with starting fluid.. I was relaxed and just thought to myself naa... its just my varnished gas.. (completely rebuilt/dipped the Qjet a week ago). No idea why it stopped today.. lol but tore apart that thing maybe 4-5 times. the last time i opened it i found the valve that hangs in the float arm to stop the gas flow was out of its guide hole, so fixed that and it started right up.. >
was AWESOME!.. 3-4 years been very slowly trying to get this running.. passed 2 cop cars on the way home.. . smokes like KRAZY!!.. just glad i was coasting down a hill when passing those cops.. huge smoke signals everywhere i was going.
Question tho... Its had a rumored trany prob (sitting for 16yrs) and i do know its a stock 3speed with a 402 engine. only reason i ask is because of the high shifting speed and a slight kick when it does shift. what sounds a good speed to shift out of first? 25-35mph? I know you guys are going to ask what kind of transmission but.. i've never looked to figure it out.
WOOHOO!! Thanks
"Feel it's not a bonfire unless they can see it from space?" ~ Capt. Morgan
1970 Cst - 20 402
1984 Chevy C30 6.2L Diesel crew cab Dualie
doctrouble is offline   Reply With Quote
Old 09-30-2011, 09:25 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: First Drive
Glad to hear that you got to take it on its first drive. It is a great feeling.
Your bumper looks just like the one that came on my '71 when I bought it years ago.
Sorry I can not help you with the transmission question since all I have ever owned are Sm-420 or SM-465 manuals. I am sure some one will chime in though.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-30-2011, 09:39 AM   #3
trapperjack
trapperjack's Avatar
Re: First Drive
Congrats on getting it legal. On the transmission....This happened to me years ago with a Bronco I had. Bought it for cheap after only going around the block. Noticed on the way home with it that it seemed to rev a little high before shifting, then would bang into gear hard, just like the powerglide in my great uncle's (now mine) 68 panel. I drove back to the guy I got it from. Turns out he had installed a shift kit in it, and I drove the doors off that bronco for years, never missed a lick. Just a thought.
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 10-01-2011, 02:45 AM   #4
doctrouble
doctrouble's Avatar
Re: First Drive
HA...so my smoke signals were because i forgot to plug in a spark plug...
On the way home from work,, when it started, it was smoking more than usual and only on the left. Slightly worried about my starter because it turns over couple times then stops for a split second and keeps going, but usually starts after the pause.
Couple other things i've noticed is that, ITS AWESOME TO DRIVE!!.. but.. also when it was starting it had a knocking noise in the very beginning went away shortly after it was running though.
Very frequently it will stall sitting in drive at a red light, it'll start right back up but only after 2-3 mins. If i instantly try to restart it, it'll just keep turning over.
Noticed the head turners already.. was test driving after i found the spark plug wire and drove past this guy that did a complete 180 with his head twice at his house as i drove past
Not sure what a "shift kit" is. If that's what was causing your shifting to kick or taking it off gave it the kick.
Tomorrow i'll recheck the oil and gap my spark plugs. (friend keeps saying he's getting a massage sitting in it..)
But any ideas about the starter pause and the restarting after it stalls?
I LOVE this site.. I would be honored to meet any one of you
1970 Cst - 20 402
Old 10-01-2011, 08:00 AM   #5
Daves70
Daves70's Avatar
Re: First Drive
If it has a th350 transmission it probably shifts high because your kickdown cable is adjusted too tight.On the passenger side of the carb is a cable going to your trans.There is a plunger type thing there so you can adjust it.Loosen it off one notch and try it.It may need more but keep adjusting until it shifts right.
Daves70 is offline   Reply With Quote
Old 10-01-2011, 01:56 PM   #6
webfoot
Re: First Drive
I would guess you don't have your vac module hooked up on the th 350, or the line is pinched somewhere. Follow the vac line on the pass side down to the vac module.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 10-07-2011, 01:35 PM   #7
doctrouble
doctrouble's Avatar
Re: First Drive
Thanks for the replies. The only 2 hosing tubes i could see coming out of the Qjet was one going to a vacuum gauge in the cab and one going to the distributor. The red circled goes to the distributor and the green goes to my gauge.
1970 Cst - 20 402
Old 10-07-2011, 02:53 PM   #8
webfoot
Re: First Drive
The vac fitting going to your gauge (green circle) is what would normally run the vacuum modulator on the transmission.
-me
Old 10-08-2011, 12:26 AM   #9
doctrouble
doctrouble's Avatar
Re: First Drive
Ahh.. So to properly hose a vacuum gauge, would be to "T" hose it off to the gauge and one to the modulator on the transmission?
1970 Cst - 20 402
Old 10-08-2011, 12:35 AM   #10
bigbadchev72
People know me
bigbadchev72's Avatar
Re: First Drive
Your high rpm shifting and smoke could very well be a ruptured diaphram on your vacumme modulator, it is sucking tranny fluid into your intake and burning it. Pull the vacuum line off the modulator on the side of the tranny and see if any fluid dribbles out. If so that is your problem.
Edit: The new modulators are adjustable, there is a small screw inside the nipple turning it clockwise or counter clockwise will raise or lower your shift points
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
