Old 10-08-2011, 03:27 PM   #1
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Adding a tach
Tach housing and a nontach housing are different though. I guess you can dremel and glue and duct tape.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 10-08-2011, 07:15 PM   #2
Cramitthefrog
It's always something
Cramitthefrog's Avatar
Re: Adding a tach
You can also use one that came with a clock.
Cramitthefrog is offline   Reply With Quote
Old 10-08-2011, 07:45 PM   #3
RandyP
RandyP's Avatar
Re: Adding a tach
The one for the clock does not have the connections for the fuel gauge to hook up to the printed circuit. The clock is wired separately from the actual cluster thus they had no pins for connections.
Old 10-08-2011, 07:57 PM   #4
Cramitthefrog
Re: Adding a tach
Correct, that is why you make small jumper wires to go from the original location to the clock position. It is alot easier than it sounds, I used about 4 different clusters to build my tach cluster.
