Old 10-08-2011, 07:57 PM   #1
trev1
Question Cooling Fan CFM Question
For the Guys out there using Electric Cooing Fans. What CFM are you using? I can get two 10" Pusher/Puller fans that are rated at 1250 cfm. Its around $20.00on Ebay each? So would 2500 CFM be enough for a 350 at .40 over flat top pistons, 292 grind Erson cam, and 193 heads??????
I welcome all opions are definately welcomed!!!!
trev1 is offline   Reply With Quote
Old 10-08-2011, 10:59 PM   #2
hjewell2
hjewell2's Avatar
Re: Cooling Fan CFM Question
should work as a puller set-up. Make sure you make or use a shroud it will make a big difference. of course with two ten inch it may not be possible to use a shroud because of the stagger so you may need to mount directly to rad. I have seen one ten inch mounted at the open end where the pump mounted fan would be, looked ok do not know if the person had cooling probs I never asked him.
hjewell2 is offline   Reply With Quote
Old 10-08-2011, 11:45 PM   #3
oldspowered67C10
2500 CFM is plenty if indeed they do move that much air. Different fan manufacturers rate CFM differently so beware. Like hjewell2 said, mount them as pullers and a shroud is definitely a good idea. Should work though.
oldspowered67C10 is offline   Reply With Quote
Old 10-09-2011, 08:30 AM   #4
trev1
Thanks for the help... Any one got any pics? I will probally fab the shroud up myself. You said mount them as pullers. Does that mean mount them in the front (outside) of the rad, or the back (inside) of the radiator? I would think that I would want to pull fresh air from the outside accross the radiator... Right?
Old 10-09-2011, 10:17 AM   #5
Andy4639
Old member
Andy4639's Avatar
Cool Re: Cooling Fan CFM Question
Pulling means behind the radiator pulling the air through.
Pushing would be in front pushing the air through. A shroud is a biggie on either one.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-09-2011, 10:23 AM   #6
Wrenchbender Ret
Puller is in back of the rad. It has more efetioncy then pusher in front. I have a single 16 in. 2800 cfm puller on mine. It is marginal on a real hot day with A/C on & in traffic. Like Oldspower says, it may not put out that much.
Sorry, my spell correcter got away.
Wrenchbender Ret is offline   Reply With Quote
Old 10-09-2011, 08:03 PM   #7
trev1
Thanks! Thats the way I will mount them. I am going to buy two 12" fans next week and make the shroud for them. I'll post pics when I get it put together.
Old 10-09-2011, 08:41 PM   #8
crazy longhorn
Fabricate till you "puke"
I have a pair of 14" fans on my longhorn(Said to pull 1350 ea). They are mounted on a homebrew shroud (built from a tin shelf). The rad is a 4 row copper/brass, & I run painless controls (185 on 165 off). I opted for a 160 stat, & this combo flat works! The old truck runs around 180 on the hyway(no fan action), & will flat azz idle all day long in traffic on the 90-95 degree days in Illinois, & never bust 190 on the temp.They switch off/on in traffic. CrazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-09-2011, 09:13 PM   #9
Ackattack
Ackattack's Avatar
I got a jeep fan from summit and mounted it in the stock shroud (as others have to). I'm not sure on the CFM, but it was only $55 (with a price match)
Ackattack is offline   Reply With Quote
