10-10-2011, 12:45 PM | #1 |
What diff will fit in this beast
ok I just put a 87 front suspention in my 69 GMC . Now we have 5 bolt pattern and disc brakes so what diff will fit in this truck ? if I can use one from a 73-87 and have to put my own perches on , do they make a kit to install panard bar ?
when the smoke clears all your gunna see are my Tail lights |
10-10-2011, 05:51 PM | #2 |
Re: What diff will fit in this beast
Yes, a kit is available to add the newer rear to your truck by adding a panhard bar and a bolt in bracket . also an axle swap may be one of the more economical ways to get 5 lugs in the rear. If you do that , you can just purchase 5 lug drums for a 71-72
10-10-2011, 09:32 PM | #3 |
x2 on just replacing the shafts.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
