10-10-2011, 09:48 PM | #1 |
Can I use Factory AC setup?
I am wondering if a person can keep the original factory air set up for AC? If not what are the options? I need to keep it cheap so No ac is ok. But since it came with it, why not have it?
If not anyone know what compressor it is? And if it would make a good on board air compressor?
Confidence is the feeling we have before we fully comprehend the situation |
10-10-2011, 10:07 PM | #2 |
Re: Can I use Factory AC setup?
You can keep it original. It's not hard at all to do. Look up Classic Auto Air. They can re-calibrate the POA valve for R134a. Or, you can buy a POA valve eliminator that will cycle the compressor on and off. Change your oil to ester (10-12 ounces i think), replace all o-rings, replace the drier and expansion valve, pull a vacuum for 30 minutes, and charge it up until the big line on the back of the compressor has sweat dripping off it. The compressor is an A6 BTW. They're pretty much bulletproof and can be used for OBA.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
