Old 10-09-2011, 06:22 PM   #1
rick0312
rick0312's Avatar
passenger side tail light
passenger side taillight and side marker not working. all other lights are fine. tried to isolate the hot wire going to that light and got a reading of 2.0 volts. also license plate light is out too. any suggestions?...........thanks
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 10-09-2011, 06:38 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: passenger side tail light
First... If you haven't done it already, go and purchase a few ground straps at the local auto parts store.
Here's the reason why. These lights use the bed/frame ground to work and after 40+ years the bolts are rusty and covered in road grime so that you don't get a good ground back to battery negative post.
Here's what I did to completely ground the whole truck.
-Bought new battery cables and made sure the neg one made a good connection to the engine.
-Put a strap from the back of the bed to the frame.
-Another strap from back of the cab to the frame.
-Made sure I had a good ground to the cab from the back of the engine.
-Placed another strap from radiator support to the battery neg post.
All my light gremlins went away and my charging gauge started working again.
68gmsee is offline   Reply With Quote
Old 10-09-2011, 08:04 PM   #3
bmfm64
bmfm64's Avatar
I'd definitely check grounds but it sounds like the wire going to the taillight on that side has a break. Usually if a ground is bad the whole back end quits working or functions erratically. I would start at the connection under the rear of the truck where the rear harness connects to the main harness, figure out which one is the park light wire (brown I think) and follow it until you find the break. If the drivers side works there is a break because the same wire feeds all the park lights and plate light.
bmfm64 is offline   Reply With Quote
Old 10-09-2011, 08:46 PM   #4
68Gold/white
I've had similar problems, trying to remember what all was wrong.....
Check the connection at the socket area. seems like that was a problem w/ mine. If the pass side has a problem, check the other side, while you are having all this fun...
You can't have too many grounds, anywhere on any vehicle.
If you've never completely looked over your wiring, as bmfm stated, you need to look it over, it's not too difficult, there's a harness that's on the frame rail.
68Gold/white is offline   Reply With Quote
Old 10-09-2011, 08:58 PM   #5
big_al_71
big_al_71's Avatar
This happened to ny truck last week after we finished installing my autometer gauges my truck has all the wires brand new and i mean the complete truck extra grounds and all the problem was in the dash harness there is a plug that connects to another harness that plug was slightly loose we reconnected it and the rigjt side lamps started working we tie wrapped it so it wont come apart again. Check that plug is right behind the speedo head just above the fuse box.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-09-2011, 11:29 PM   #6
rick0312
rick0312's Avatar
line had a break in it. luckily it was close to the light. now I hope i remember how to put everything back. PO hack in a trailer harness so that is making things a bit tricky.
Old 10-09-2011, 11:33 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Glad you found the problem. I forgot to add on my post that the grounding were a first step before looking for other gremlins.
I chased a problem for days until I found it was bad grounding that were making my lights act up. They would work sometimes and then they would not work. Really made no sense at the time.
Old 10-10-2011, 01:37 PM   #8
stsalvage
Scrapper 1
stsalvage's Avatar
a new repop harness back there will run you from 40.00 to 85.00 from M&H wire harness WWW.truckandcarchop.com
stsalvage is offline   Reply With Quote
Old 10-10-2011, 10:43 PM   #9
rick0312
rick0312's Avatar
hooked light back up but must ahve done something wrong. all lights come on, but when I hit the brake the passengerside brake light goes out!!!. what did I do wrong?.thanks
Old 10-10-2011, 10:49 PM   #10
MacGyver72
MacGyver72's Avatar
That DEFINITELY sounds like a ground problem to me. It also can be related to your trailer light hookup. The others are right. Ground everything you can.
MacGyver72 is offline   Reply With Quote
Old 10-11-2011, 12:56 AM   #11
rick0312
rick0312's Avatar
all is working fine now. i removed the trailer harness and cleaned up the grounds. thanks for all the input. you guys are the best!
Old 10-11-2011, 12:58 AM   #12
MacGyver72
MacGyver72's Avatar
Excellent! Glad you got it fixed.
