10-11-2011, 09:48 PM | #1 |
1972 2wd Blazer
Hi I am new to this forum but I have purchased a 1972 2wd Blazer that is going to need quite a few replacement panels. I have already purchased the fenders, rocker panels, inner rocker panel, the rocker boxes, rocker box end plates and support. What I am going to need is to find floor pan other than patch panels for the front, and a bed floor, from what I have seen the shortbed truck bed floor is to long any ideas or suggestions will be greatly appreciated. Thanks will download pix soon.
10-12-2011, 08:44 AM | #2 |
Re: 1972 2wd Blazer
I don't know of anyone that sells a Blazer floor pan. I bought a truck floor pan from GMC Paul's and I can use about 85% of it.
Here's the page that the floor pan is on. It's the 6th item down on the list. http://www.gmcpauls.com/Patch_Panels.htm |
10-12-2011, 10:01 AM | #3 |
Re: 1972 2wd Blazer
If you go with a full floor pan, which would a good choice, make sure you get one with the forward seat brace. The one pictured doesnt have one
Welcome to the boards
10-12-2011, 10:10 AM | #4 |
Re: 1972 2wd Blazer
Who sells full Blazer floor pans?
10-15-2011, 09:46 PM | #5 |
Re: 1972 2wd Blazer
Hey thanks for the info. Would like to know if i should weld in support braces in the door openings and across the bed to keep things in place when i start the replacement of the rocker boxes and floor pan patch panels. Also looking at using a rotissereie that a friend has to do this work will this help everything stay inline? thanks for everyones input on this
10-16-2011, 08:55 AM | #6 |
Re: 1972 2wd Blazer
If you want to be safe I would brace the tub. If you are going to use a rotisserie, I would brace it for sure.
12-03-2011, 10:55 PM | #7 |
Re: 1972 2wd Blazer
What's going on here? Progress pictures?
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
12-07-2011, 09:16 PM | #8 |
Re: 1972 2wd Blazer
Hey hvac,I replaced my front floor with a cab floor and the bed part with a rust free short bed floor.I can dig up some pics if it will help.
12-07-2011, 10:30 PM | #9 |
Re: 1972 2wd Blazer
12-07-2011, 10:47 PM | #10 |
Re: 1972 2wd Blazer
I actually used some of the truck floor and two new floor pans. I cut the bad part off the back of the blazer and measured the truck floor and cut and welded. O yea it's easier with the quarters off.
12-07-2011, 10:50 PM | #11 |
Re: 1972 2wd Blazer
a couple more
01-13-2012, 05:21 PM | #12 |
needs more $$$
Re: 1972 2wd Blazer
3 months and the only pics of this project are from another ride?...What's going on here?! Haha...let us see what ya got hvac...any progress?
1970 2wd Blazer |
01-16-2012, 09:00 PM | #13 |
VA72C10
Re: 1972 2wd Blazer
in "if" this build takes place
Looking for a 67-72 swb or blazer project in or around VA. |
01-17-2012, 12:08 AM | #14 |
Re: 1972 2wd Blazer
I'm in too, I love seeing these puppies come back from the dead!
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
