Old 10-08-2011, 11:11 PM   #1951
VA72C10
VA72C10
VA72C10's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Looks good and sturdy too. Nice work!
Old 10-09-2011, 02:41 PM   #1952
Allenconstruction
Allenconstruction's Avatar
OK we're all back from church what's next Drew?
By the way excellent progress, looking great!
Allenconstruction is offline   Reply With Quote
Old 10-10-2011, 09:04 AM   #1953
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
I worked a while on it after church and got all my suspension brackets fabricated and painted up well. I also mounted my rear air ride sensors up inside the frame rails to protect them as best that I could.
Also seen in the shot is my upper shock mount that was angled the wrong way since I cut it off the frame ahead of the axle and flipped it to the rear. It was going to angle the shock towards the pumpkin instead of towards the outboard area. A buddy told me of a great trick, he said to ream the hole out on one side to get the shock to angle the way you want it, and then weld a thick washer to the side of your reamed hole to create a new tight hole for the shock bolt. Worked like a charm, thanks Chris.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 10-10-2011, 09:08 AM   #1954
67cheby
67cheby
67cheby's Avatar
nice, i need to get mine mounted
67cheby is offline   Reply With Quote
Old 10-10-2011, 04:35 PM   #1955
VA72C10
VA72C10
VA72C10's Avatar
Good progress...now get back to that wiring
Old 10-10-2011, 05:06 PM   #1956
FL71C10
tough crowd!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 10-10-2011, 05:27 PM   #1957
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Good progress Drew!
Ryan
1969 Chevy milk truck
Old 10-10-2011, 06:21 PM   #1958
sboris
sboris's Avatar
Your progress is awsome to watch!! Great job
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 10-10-2011, 08:39 PM   #1959
CowboyProtectionUnit
CowboyProtectionUnit's Avatar
Wish I had the Talent ya do bud....... Very Very Great Build
Eric "Target" Sherwood
Professional Bullfighter For Hire
God Bless and Gods Speed!
TheCowBoyProtectionUnit@yahoo.com
http://www.facebook.com/pages/Eric-T...59496227444241
CowboyProtectionUnit is offline   Reply With Quote
Old 10-10-2011, 08:42 PM   #1960
now..... Get back to the Wiring... cause I'm stronging considering picking up an 2010 6.7 Cummins For my truck (I know your not using a diesel but your running alot of wiring an my truck is an 88 and this will be a total custom truck as well) ...and I would be picking your brain on basic wiring questions LOL
Old 10-11-2011, 11:35 PM   #1961
Ridnhi
Ridnhi's Avatar
Had to bring this back to the 1st page. We need some progress!!!
1972 K5 Auto 4x4 factory air
2007 Silverado extended cab Z71
Ridnhi is offline   Reply With Quote
Old 10-12-2011, 01:20 AM   #1962
drewskiren
drewskiren's Avatar
Here's what I've got for tonight.
Crazy brackets are grade 8 bolted to the frame and upper bag mounts. It took a while to get all the bolts lined up and tightened down.
Panhard rod is mounted and adjusted for axle centering. I must have cycled the suspension 30 times fitting and checking for clearances.
Bags need their proper bolts and air lines cut to length.
Height sensors need brackets made to connect their arms to the axle.
I have 3 inches of travel before I hit the snubbers. The snubbers hold the frame one quarter inch off of the axle brackets.
Drew
Old 10-12-2011, 01:35 AM   #1963
VA72C10
VA72C10
VA72C10's Avatar
keep the progress coming Got a lot of guys waiting with bated breath
Old 10-12-2011, 02:15 AM   #1964
tanman722001
tanman722001's Avatar
Looks great Drew
1991 GMC K2500 4X4 350/auto
1991 Chevy S10 ext cab.
1990 Chevy S10
1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto
tanman722001 is offline   Reply With Quote
Old 10-12-2011, 02:48 AM   #1965
Dieselwrencher
Great work!
Ryan
Old 10-12-2011, 09:21 AM   #1966
oldman3
oldman3's Avatar
Are you happy with the 3" of travel, or did you want more? Set up is nice....Jim
oldman3 is offline   Reply With Quote
Old 10-12-2011, 10:08 AM   #1967
mrchrishill
mrchrishill's Avatar
I felt honored to get a tour of the shop and a private tour of Young Frankenstein last night. It is really hard to tell from your pictures that you are building a miniature truck... the thing looks tiny up close, who knew an 18-inch foot truck could look so real up close!
Great work, keep the updates coming!
mrchrishill is offline   Reply With Quote
Old 10-12-2011, 10:19 AM   #1968
67cheby
67cheby
67cheby's Avatar
KILLER nice looking suspension work !!
Old 10-12-2011, 03:00 PM   #1969
drewskiren
drewskiren's Avatar
I really don't know how much travel I should have for an air bag suspension. Can anyone give me and idea if 3 inches is good or not?
Drew
Old 10-12-2011, 04:22 PM   #1970
67cheby
67cheby
67cheby's Avatar
i dont think the length of travel matters as much as running your bags at the proper ride height to get the best ride, i have tons of travel on the rear of mine and according to ride tech my bags should be 10 inches tall at ride height for the best ride quality
Old 10-12-2011, 05:31 PM   #1971
drewskiren
drewskiren's Avatar
My Firestone bags are to be at 8.75 inches at normal ride height which I have done. My question is though, how much travel will they need to hit a big bump and still not contact my snubber? I think of Baja racing trucks that hit huge bumps and float across them smooth as silk, but they have 15 inches of travel to soak it up. I just have no experience here. The bag fully collapses and rolls onto the bottom axle mount with only 2.25 inches of downward travel. When I dump it fully (3") the bag actually wrinkles up in the middle some, so it seems to me the bag only has about 2 inches of safe downward travel. It is hard for me to understand that 2" of travel is going to result in a smooth ride. These are the rolling sleeve type bags that are supposed to ride smoother than double convoluted.
Drew
Old 10-12-2011, 05:40 PM   #1972
67cheby
67cheby
67cheby's Avatar
hmmmmm...a question i also dont know the answer to !! i am sure someone can tell us both
Old 10-12-2011, 05:42 PM   #1973
VA72C10
VA72C10
VA72C10's Avatar
Doesn't sound like enough to me...I'd start a thread in the suspension forum....
I believe it's pressure and height together that are important and allow a comfortable ride....
...most bagged trucks I've seen have 8-10" travel though...
Old 10-12-2011, 05:44 PM   #1974
drewskiren
drewskiren's Avatar
FYI
I am focusing on the rear area of the truck so I can call it done and mount the bed. That would allow me to line up the upper trim all the way down the truck and figure out where to paint the white on my fenders. When I tape up the truck to paint the white I can also do the Al's bedliner.
Drew
Old 10-12-2011, 05:47 PM   #1975
drewskiren
drewskiren's Avatar
I am only talking here of course of downward travel, my up travel over a bump would also be 3 inches or so depending on my limit strap or shock length. That would equate to 5 inches total.
Drew
