Dually Bed Repair
I got a 1985 Chevy C30 3+3 and the previous owner had cut the area out between the wheel wells to put in a goose neck hitch. I am wanting to put the area back in. I have got parts cut from another bed already so wont have to buy patch panels. I am looking at different options:
1 Just weld them in with the mig and bed line 2 roll flange and rivet and glue in then bed line 3 add bracing and weld in and then bed line 4 flange and stitch weld in and bed line I am open to other suggestions as well if any one has got any. Will be adding in a newer style Fifth wheel and goose neck that has the rail system so can still use the bed but can pull both types of trailers. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Dually Bed Repair
Im assuming that youre going to use this truck as more than a decorative piece. Id prolly pull the bed and have the patch panel welded in from above a little larger than the cut area then go under and weld over there. Id also make sure that if any of the cross braces were cut that i would sister thema few inches on either side of the cut
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
I would get a b&w turnover ball gooseneck hitch. It
mounts under the bed and you can flip thr ball over and there is nothing in the way in the bed. With the rails mounted in the bed you can't slide anything in there very easy. You can also get a 5th wheel adaptor for the turnover hitch so you will be able to pull both. It requires a hole in the floor of thr bed, but it's well worth it. Posted via Mobile Device Posted via Mobile Device
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
#4 | |
Oh so they cut a big chunk out of that truck then. B&w hitches are really good. I plan on getting on for my crew cab dually at some point.
