Old 10-12-2011, 01:10 PM   #1
matts86chev
matts86chev's Avatar
tune up
So as of late my truck has been freaking me out. I've gotten real used to how it runs and sounds when its right and lately it ain't right. It stalled and died on the interstate Friday and since then it hasn't quite died but it runs rough at idle, at fast idle it is fine but once it kicks down, or I put it in gear it runs rough, sounds like its about to stall and vibrates different. I replaced the fuel filter, sprayed wd40 all over the vacuum lines and non seem to be sucking it in. A few are pretty janky so I am going to replace/reassemble them. Aside from that I got a new dizzy cap and rotor, new spark plugs and new spark plug wires to put on. I just don't know what to do past that if none of those solve it... help!
Thanks!
1986 Chevy C10 305 5.0L Work in progress...
matts86chev is offline   Reply With Quote
Old 10-12-2011, 01:21 PM   #2
379redneck
379redneck's Avatar
Re: tune up
Put the new stuff you bought for it on and see if it helps. If not, check the timming and fuel pressure.
87 GMC Sierra 2500 4x4 350/TH350/NP203 Flow Tech long tube headers, throttle body spacer, Edelbrock Performer cam, true dual Flowmaster 40s, 6 inch Superlift suspension lift
2000 silverado extended cab stepside 5.3l. Stock for now
379redneck is offline   Reply With Quote
