Old 10-12-2011, 05:32 PM   #1
matchstick
matchstick's Avatar
Converting from 4wd to 2wd
Can I do this by simply changing out the front cross member? I believe the frame on a 4wd is arched more or something.
matchstick is offline   Reply With Quote
Old 10-12-2011, 05:34 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Converting from 4wd to 2wd
whole front suspension has to be changed out basicly but yes it can be done
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-12-2011, 05:41 PM   #3
matchstick
matchstick's Avatar
Is the frame not different?
Old 10-12-2011, 05:45 PM   #4
J Knight
J Knight's Avatar
It would litterally be easier to swap your frame to a 2wd frame.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 10-12-2011, 05:49 PM   #5
INSIDIOUS '86
1/2 ton frame is is a 1/2 ton frame only diff i beleive if its been loaded with 2wd or 4wd running gear from factory same with 3/4 ton frames to
Old 10-12-2011, 05:50 PM   #6
matchstick
matchstick's Avatar
I am looking at buying the crew cab project off 72supercheyenne. The frame he has is a 4wd. I have a 2wd parts truck that I can take everything off of. I believe these frames are different and do not know if it's possible to use the 2wd cross member and a arms in place of the 4wd stuff.
Old 10-12-2011, 05:56 PM   #7
J Knight
J Knight's Avatar
Thats the crew thats already disassembled and shortened correct?
John
Old 10-12-2011, 05:59 PM   #8
matchstick
matchstick's Avatar
Yes, that is correct. I don't suppose it matters. I have a welder and if it's different I dan cut the frame off and put the 2wd section in it.
Old 10-12-2011, 06:04 PM   #9
J Knight
J Knight's Avatar
Thats a little different, I thought your OP was about a complete truck. Should be relatively easy then, but youll need more than just the front cross member.
John
