#26 |
Re: 86 crew cab "Full Frame" build
Very impressive build!
You'll love runnin the Accuair setup, it's bad a$$.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
#27 |
#28 |
Second Chance Program
Wow! That motor alone had to run you in the $15k-$20k range at least! Any eta on when the truck will be "done"?
#29 |
#30 |
Here is the main frame that goes under the cab. I'm very pleased with the outcome.
#31 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Wow!
This thing is going to be amazing!
#32 |
WOW again..... very nice....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... ![]() |
#33 |
Tot Roddin'
Subscribed.... this is going to be one heck of a build.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#34 |
Home Built '87
This will be a fantastic truck!
Here's the only yellow truck pic I have along the same lines as your rendering, but your yellow will look more intense (& better) I think.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#35 |
Well I got the call from Baer brakes today saying my brakes were finished. Here is a picture of the calipers and hats. When they get to Nate he's going to get me a picture with the set up behind the wheel.
#36 |
6>8 Plugless........
![]() Join Date: Sep 2007
So basically I'm guessing they cut the floor clear out of the cab and then set the cab over this portion of the frame so you can lay as low as you can and have all the drive line flush with the bottom? Pretty sweet!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#37 |
Correct, now the limiting factor is the front tires almost hitting the hood.
#38 | |
#39 |
#40 | |
#41 |
#42 |
![]() Join Date: Mar 2010
I'm in. Looks good so far.
#43 |
deadly......makes my build seem like crap! lol...
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
#44 |
I'm looking forward to this. Hell yeah!!!!!
Posted via Mobile Device |
#45 |
Cool project, One suggestion though, you should swap out those 26s for some 24s. I think a 405/25/24 out back would be a little better seeing how the motor you picked up makes so much power.. That 275 just isnt enough.
#46 |
Pardon me for being snoopy (no pun intended), but why are you using a bunch of NOS parts? Why not let someone restoring a truck to original have those and you get aftermarket parts?
#47 |
This truck is going to be a full custom show truck. Aftermarket parts will not fit the way I want them to so that's the reason for the NOS parts being used.
#48 |
Got an update from Nate today that my brakes from Baer showed up. He said it felt like it was Christmas at the shop.
#49 |
Those things are massive!
#50 |
:-/ Seems like with all the custom work being done making aftermarket fit wouldn't be a problem. Guess I'm just a sucker for original, I hate seeing nice 60's era cars chopped and caged as drag cars.
