Old 10-12-2011, 11:17 PM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
Cig. Lighter questions?
Hey guys, so my C10 i believe never had a cig lighter in it as it has a "plug" with red paint over it where the cig lighter is next to the ash tray. Anyway, i have a Casco full lighter replacement on the way, details below.
38-5016 1 LIGHTER SOCKET & RETAINR-CASCO
38-5012 1 CIGARETTE LIGHTER-W/KNOB
Anyway, beyond install my next main question is wiring, IF my truck didnt ever have a lighter in it, will i have a wiring pigtail anywhere for a lighter?
IF not, how do i go abut wiring this up and will i need to wire it through my fuse box or just hard wire it to existing wires?
Lastly, any first hand advice on this is greatly appreciated, wiring is NOT my strong point!!!!!
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 10-13-2011, 02:16 AM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Cig. Lighter questions?
You can just hardwire it in. It's only one or two wires, if I remember correctly. The truck is 150 miles from me or I'd look for you.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 10-13-2011, 03:03 AM   #3
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I've had to swap out my lighter a couple of times using a Casco unit. Odds are, if the truck didn't come from the factory with a lighter, I seriously doubt that you'd have an unused pigtail waiting for you under the dash. All you need is one wire - a hot lead from your fuse block to the back of the lighter - and you're good to go. The unit is grounded by the ashtray. Hope this helps.
78 Big10 454 is offline   Reply With Quote
Old 10-13-2011, 07:30 AM   #4
Goldfinger
Goldfinger's Avatar
Mine only uses one wire for + at the end of the cig lighter. the rest is grounded through the dash.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 10-13-2011, 11:46 PM   #5
ProStreet83C10
Drag Racer
ok sweet that makes me feel better about it!!!
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 10-14-2011, 01:23 AM   #6
78 Chevyrado
IIRC correctly, my stock lighter is on the same fuse as the courtesy lights.
78 Chevyrado is offline   Reply With Quote
Old 10-17-2011, 10:10 PM   #7
ProStreet83C10
Drag Racer
ok....im completely at a loss now, i got my Casco lighter assembly on Sat and when i went to put it in yesterday the lighter socket diameter is larger than the diameter of the hole next to my ashtray. what the heII is going on with this and why wont it fit, its for an 81-87 GM pickup......it wont go in from the front side OR back side, wont even ATTEMPT to fit in the hole.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 10-17-2011, 11:11 PM   #8
Your41Plague12
Part of it unscrews if I remember right, and you put the back piece behind the hole and the front piece on the front. Hard to explain, but that's how I did it if I remember.
Steve
Old 10-17-2011, 11:22 PM   #9
ProStreet83C10
Drag Racer
but it looks like one solid unit???
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 10-17-2011, 11:39 PM   #10
J Knight
J Knight's Avatar
Thats right, it has inner and outer pieces.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 10-17-2011, 11:55 PM   #11
Your41Plague12
OP, post some pics of what you have. Maybe they gave you the wrong one. I just got a universal one and it fit just like the original did.
Steve
Old 10-18-2011, 12:55 AM   #12
ProStreet83C10
Drag Racer
ok i will tomorrow im goin to bed now...thanks so far guys! hows it come apart by the way, i need to know where it screws/unscrews
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 10-18-2011, 01:01 AM   #13
Your41Plague12
The housing itself should be two pieces, separate from the lighter. It should unscrew, and you'll see how it goes. The back part goes behind the hole in the ashtray and the front goes on the front part of the hole. Then wire the housing up and stick the lighter in. Light em' up!
Steve
Old 10-18-2011, 08:03 AM   #14
ProStreet83C10
Drag Racer
the only thing i see to unscrew is a stud in the back with a small nut.....other than that the housing looks completely solid and one piece....
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 10-18-2011, 07:01 PM   #15
ProStreet83C10
Drag Racer
no one else??
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 10-18-2011, 07:20 PM   #16
ProStreet83C10
Drag Racer
ok guys, a quick google search shows how the lighter housing and retainer comes apart, bt now, theres a male spade on the retainer and a copper threaded shaft with small nut directly in back side of housing, is that for a power and ground wire? IIRC you guys said the lighter is grounded through the ash tray, is that what the spade does, rest on the metal? also, i need to know what the copper color threaded shaft is on the direct back center of the housing.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 10-18-2011, 07:22 PM   #17
hatzie
Moderator
hatzie's Avatar
The spade on the housing is a ground lug in case you're mounting in a plastic panel.
The stud on the end is the + connection. It allows you to use a ring terminal if you don't trust the press on lighter terminal.
Old 10-18-2011, 07:23 PM   #18
J Knight
J Knight's Avatar
Post a pic of what you have. Maybe it didnt come with both pieces.
John
Old 10-18-2011, 07:35 PM   #19
ProStreet83C10
Drag Racer
no it did because i can push the element in and it locks in until i pull it out, so their all there, and the outer "tin" looking piece is there, also Hatzie, what "push on" terminal are you speaking of??????
OH,. and i forgot to mention, if i tie this into an exsisting fuse on fuse block, what fuse do you guys recc. i tie into?
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 10-18-2011, 10:20 PM   #20
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
if it was me, I would splice into the radio's hot wire if you have a aftermarket radio..
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
