Old 10-12-2011, 09:00 AM   #1
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
What axle ration in a longhorn?
1972 3/4 longhorn LS9 350, Eaton rear, no ratio on SPID so what would this truck have in it? Anyone know was the standard issue?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 10-12-2011, 10:19 AM   #2
Re: What axle ration in a longhorn?
The standard ratio would be the same in any C/20 or K/20 with HO52/automatic transmission/SBC...4.10
Old 10-12-2011, 10:48 AM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
special-k is correct. All Longhorhs have Dana 60 rear ends. All Dana 60s have a tag bolted to the inspection cover. The tag tells you what the ratio of your rear end is. That is unless it was removed. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-12-2011, 11:02 AM   #4
Vintage Windmills
Vintage 4x4s
Thanks guys. I guess this truck must have had a rear end swap then with the HO52 Eaton in there. All bets are off then if not original to the truck.
Old 10-12-2011, 02:41 PM   #5
crazy longhorn
Fabricate till you "puke"
My bet is that the diff is original, my sb powered longhorn also had an HO52 eaton(4.10 gears). I think you will find the BB powered longhorns to use the Dana 60 crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-12-2011, 02:50 PM   #6
I don't know about Longhorns very intimately. But,it is true that any C/20 with the BBC got a Dana60 to get the 3.54 ratio. At least with an automatic it did. So,that would include Longhorns.
Old 10-12-2011, 03:41 PM   #7
Classic Heartbeat
I am probably mistaken. I haven't ever owned one, nor had customers come in with one that wasn't a big block except 1. That was a GMC and it had a Dana 60 with 4:10 gears. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 10-12-2011, 06:50 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've had a 70 CST/20 and a 70 C/30, both 350/TH350 longhorns... Eaton HO50 and HO72 respectivly, both 4.10. Also had a 71 (maybe 72) Cheyenne/20 longhorn, 307/th350... eaton HO52 with 4.10.
You didn't list if it was a manual or auto tranny.... auto would be 4.10 maunal would be 4.57.
Big block C/20 trucks automaticly got the Dana with the 3.54 unless optioned otherwise.
No dana in one ton, 4.10 with the big block C/30
Dana rears were founs in a handfull of inlines or small blocks, but gears were basicly the same as eatons, but normally off by .01 (4.11 instead of 4.10, 4.56 instead of 4.57)
A ration is a serving of chow... these are ratios.
Old 10-12-2011, 08:23 PM   #9
Vintage Windmills
Vintage 4x4s
Good info. Its an auto.
I guess I was hungry when I typed the title!
Old 10-12-2011, 10:04 PM   #10
Longhorn Man
LOL @ being hungry!
Old 10-12-2011, 11:20 PM   #11
SS Tim
SS Tim's Avatar
Don't know, but for what its worth, I do have pictures showing Longhorns with as follows
70 GMC 2500 350/auto Dana
71 Chevy C30 400/4spd Eaton
72 Chevy C20 350/auto Eaton
and last
71 Chevy C30 srw 350/4spd Eaton (cc being passed off as a bedless Longhorn)
Also here are clips from the '72 truck data book
SS Tim is offline   Reply With Quote
Old 10-13-2011, 08:23 AM   #12
GM rationed the same ratios in Longhorn C/20s as 127" C/20s
