Old 10-09-2011, 01:31 PM   #26
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: need some wisdom, shes not running right.
Why not put the spacer back on
Old 10-09-2011, 02:49 PM   #27
RUSHNBOBO
Originally Posted by ihatericeburners View Post
I had a carb spacer and removed it. Now its not running like it used to 6 months ago before the spacer at higher rpms. I haves adjusted the timming, jetting, and I went ahead and left the water pump belt on for now.
First off how tall and what type of spacer are we talking about (4hole or open)? 4 hole spacers can lower the power band slightly ....open spacers can raise it slightly. Spacer tuning is a hit or miss experience..... some motors may show a small gain with a taller spacer, and some may lose a little horsepower , some do nothing.
If your motor is running that much worse I highly doubt it's just the spacer.
When you say "now its not running like it used to 6 months ago"....did you also change something else at or around the same time, or was it just the spacer ?
RUSHNBOBO is offline   Reply With Quote
Old 10-09-2011, 10:52 PM   #28
ihatericeburners
ihatericeburners's Avatar
Just the spacer. And its a 4 hole. One inch tall. She ran great before the a/c and when the a/c was installed it seemed like it would run a little lean with the a/c belt on. Then I put on the spacer and it brought her back to life. Now I have removed both the spacer and the a/c belt and now have my problem.
ihatericeburners is offline   Reply With Quote
Old 10-09-2011, 11:17 PM   #29
biggestjohn
Have you checked for vacume leaks?
You said that it ran a little lean after a/c install. I would say that the extra load on engine needs a little more fuel.
Anything else I'm not sure about, because I'm totally confused. Could you please retell the sequence of events?
Please understand, I'm not trying to be rude, I'm just having trouble picturing what you have, and have not done.
biggestjohn is offline   Reply With Quote
Old 10-09-2011, 11:59 PM   #30
RUSHNBOBO
"It seemed lean with the belt on", or do you mean the compressor turned on ? ....the a/c switch in the cab.
Just the belt alone doesn't cause any noticeable drag until the a/c is actually turned on ...it's just freewheeling until the clutch is engaged (that's the switch inside the cab)...is this what your referring to ?
A Little more detailed info and I bet we can get this deal figured out for you.
Old 10-13-2011, 02:57 PM   #31
ihatericeburners
Even with it freewheeling it robbed a noticeable amount of power and with the clutch engaged it was worse. But that's not the problem now because I removed the belt to gain the horsepower lost. Also, I don't have any vacume leaks. And its Mech. Secondaries.
Old 10-13-2011, 08:28 PM   #32
litew8
litew8's Avatar
Did you try cleaning the carb?
project: "my happy mess"
litew8 is offline   Reply With Quote
