Old 10-14-2011, 01:41 AM   #1976
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Puzzle pieces.
I can't believe I just drilled a hole in my gas tank.
I can fix it with A-N bulkhead fitting with a hose barb attachment.
Bolted up the reshaped 72 Suburban fuel filler neck.
Ran out of time before I could hook up the hoses.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 10-14-2011, 02:02 AM   #1977
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by drewskiren View Post
I am only talking here of course of downward travel, my up travel over a bump would also be 3 inches or so depending on my limit strap or shock length. That would equate to 5 inches total.
I'd check in on the suspension forum while the bed is still off and see if they think it'll work fine. There are several guys very knowledgeable with bags that could help confirm it's okay or if some adjustment is needed...
Puzzle pieces.
Good progress! Getting closer
Old 10-14-2011, 02:09 AM   #1978
71Sleeper
71Sleeper's Avatar
Details, Details... Drew every part you add just seems like it was suppose to be there. Keep up the work.
71Sleeper is offline   Reply With Quote
Old 10-14-2011, 02:21 AM   #1979
jbclassix
Junk Yartist
jbclassix's Avatar
Drew, do you think the OE fuel cap will cause a service engine soon light?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 10-14-2011, 09:16 AM   #1980
drewskiren
drewskiren's Avatar
I'll need a 72 SEALED cap, or tune it out when I get my cat delete tune on the computer.
Drew
Old 10-14-2011, 03:22 PM   #1981
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Looking good. I think your suspension travel should be ok. It's not like you plan on driving this thing through fields or anything.
Ryan
1969 Chevy milk truck
Old 10-14-2011, 03:38 PM   #1982
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Wait...you mean you're NOT planning to use this as a hay-hauler??
Old 10-16-2011, 12:47 AM   #1983
drewskiren
drewskiren's Avatar
Saturday night picture time.
I spent a while cleaning up the shop and reading the latest Hot Rod magazine, but I did get the fuel filler hoses hooked up finally. (I had to take out the inlet and cut it shorter which meant I had to weld another reducer on to fit the larger new hose) - wasting time.
Then I moved on to fabbing up these crazy little brackets to attach to the axle to attach the ride height sensors to. I'm walking back out to paint them black so they will be dry to put on Sunday.
Drew
Old 10-16-2011, 01:04 AM   #1984
coggonobrien
is the hose rubbing on the cab sheet metal?
coggonobrien is offline   Reply With Quote
Old 10-16-2011, 01:08 AM   #1985
drewskiren
drewskiren's Avatar
Nope, I bent the edge over so if it ever did hit it would only be rubbing on a curved sheetmetal surface. And I put the hose clamp strategically so the clamp would actually hit first.
Drew
Old 10-16-2011, 06:24 PM   #1986
drewskiren
drewskiren's Avatar
I finished up the sensor mounting today and here are the pics.
I still need to weld the shock mounts to the axle tubes, install the e-brake cables, rotors, and calipers. All that can be done from underneath, so I may try to throw the bed on soon. Where's Igor and his buddies???
Drew
Old 10-16-2011, 07:51 PM   #1987
VA72C10
VA72C10
VA72C10's Avatar
Looks clean for all that's going on there. Nice work!
Old 10-16-2011, 08:11 PM   #1988
70LonghornCST
Moderator
70LonghornCST's Avatar
It looks factory!
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 10-17-2011, 01:44 AM   #1989
drewskiren
drewskiren's Avatar
Just a little sumpin sumpin.
This is just with a battery sitting on the ground so I can troubleshoot it before I get too far. My rear air lines are crossed for one thing, but hey, 2 days ago I had no suspension.
Drew
Old 10-17-2011, 01:59 AM   #1990
CowboyProtectionUnit
CowboyProtectionUnit's Avatar
Ooooo so saweett!!!!
Eric "Target" Sherwood
Professional Bullfighter For Hire
God Bless and Gods Speed!
TheCowBoyProtectionUnit@yahoo.com
http://www.facebook.com/pages/Eric-T...59496227444241
CowboyProtectionUnit is offline   Reply With Quote
Old 10-17-2011, 01:59 AM   #1991
VA72C10
VA72C10
VA72C10's Avatar
Nice!!!! Seems to have a decent amount of travel. Not as much as I've seen on some but probably plenty for a smooth ride and you're not laid out like some guys who have to raise it 6-7" just to be able to turn their tires
Old 10-17-2011, 02:12 AM   #1992
71Sleeper
71Sleeper's Avatar
Nice...I think it will be just right.
Old 10-17-2011, 08:51 AM   #1993
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the fuel filler and the suspension! Thanks for sharing the pictures and video.
Old 10-17-2011, 09:47 AM   #1994
67cheby
67cheby
67cheby's Avatar
sweet....cant wait to do mine
67cheby is offline   Reply With Quote
Old 10-17-2011, 10:02 AM   #1995
oldman3
oldman3's Avatar
Like it very much...Jim
oldman3 is offline   Reply With Quote
Old 10-17-2011, 10:39 AM   #1996
noonzor
Very awesome! This is an incredible build!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 10-17-2011, 11:38 AM   #1997
78BO
78BO's Avatar
Is it me or is that hose laying on a sharp edge? I can't tell what that is, but it just looks like it might not last. Other then that, this thing is looking sharp!
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350.
http://www.facebook.com/#/profile.ph...&id=1116781152
78BO is offline   Reply With Quote
Old 10-17-2011, 11:55 AM   #1998
67cheby
67cheby
67cheby's Avatar
someone else already asked the same thing, if you look close you can see he has rolled the edge over
Old 10-17-2011, 11:59 AM   #1999
noonzor
it may just be me, but id still slit some rubber hose and cover the edge just to make sure. even though it does look like theres a good roll on the edge. just my .02
Old 10-17-2011, 01:27 PM   #2000
78BO
78BO's Avatar
I'm with you on that one. A little security never hurts.
