1970 Chevy C-20 Cab installation and Alignment
Hi Everyone,
I need to install a cab on to the frame. Do you have any suggestions as to how to align it so all the body panels fit nice. Best Regards, Fuelie |
Restoration Virgin!
Re: 1970 Chevy C-20 Cab installation and Alignment
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
![]() Join Date: Feb 2008
subscribe. I believe that fitting the cab would have to coincide with the installation of the front end and the bed. Theres not a lot of movement available with either end nor the cab. semi tighen all of the above and then start fitting everything together. Just guessing though because I have not reached that point yet.
The more I learn, the more I find out I don't know. 69 Chevy SWB w/67 front end 4 wheel discs 468 BB 700R4 Bagged Coming around slowly |
I am a Referee of life.
Call an Indian Guru and learn patience.It's a tedious process to get everything aligned to the point most find acceptable.These trucks are 40 years old,have been around the block and brand new didn't have great door/fender etc. gaps.I haven't done one of these trucks but the older rides I have helped with took careful looking and moving adjusting and shimming.Most body men figure a lot of hours for this process so don't expect it to fall right into place.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Junior Member
If you have a 3/4 ton frame make sure you have the correct cab mount bushings, they are different than 1/2 ton.
We bolt down the cab careful not to over torque, then we align the front clip to the cab and the bed last. Like said above it is a slow process with a lot of looking, shimming and adjusting. We have found it is hard to get a perfect fit, but is possible to get an acceptable fit, with a lot of patience.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Thank you very much everyone.
