Old 10-17-2011, 03:26 PM   #1
McMurphy
McMurphy's Avatar
Re: 66 longbed fleetside
Originally Posted by juanz1947 View Post
i took my 66 for a ride today i was going to Fullerton but didn't make it the truck started over heating half way there so i stop and check the water and there was non so i let it cool down full it back up and disconnected the heater i was think the heater core maybe started to lick and full it back up and started it back up and look check out the motor to see it it was leaking out still and then see the fan was not turning i was like the the neck the belt was still there and then thought no way the harmonic balancer broke and it did so i had it tow home so i call around and ask for a harmonic balancer and autozone wanted 55 for the double grove pulley for the 250 and then i said i have a single grove pulley they said you must have a 230 motor then
can any one tell me what kind of motor i have here a pick of the motor and the pulley or do you guys need the number off the motor
Did you ever find out what motor you have?
For most the hardware the 230, 250, and 292 were pretty generic. Same intake/exhaust, alt, all that stuff was interchangeable if I am not mistaken. On the passenger side of your motor, below the spark plugs in the side of the block you have 2 plates with 3 bolts in them. Again if I am not mistaken, those are indicative of a 292. Especially if the truck was originally a 3/4 ton it would stand to reason that it would come with that inline 6, if not a 283.
You probably have a really low gear transmission too, if it is the original as well.
Doesn't hurt to run the block numbers in any case, know exactly what you are dealing with.
I like your work so far, you got me eyeballing those fender skirts, I have a stepside, but they certainly add something to your Fleetside!!
Good luck on your build!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 10-18-2011, 02:20 AM   #2
juanz1947
rusty 66
juanz1947's Avatar
yeah its a 250 from a 77 nova it has a 3/4 ton rear end i got the correct 1/2 ton rear end with 3:73 gears
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline   Reply With Quote
