Old 10-18-2011, 09:34 PM   #1
chrohm
How to grease speedo?
I took out my gauges to clean and do some lighting repairs...My speedo has always 'wavered', been accurate but jumps around a bit...Will greasing it fix it? If so what should I use, or any other ideas on fixing it?
chrohm is offline   Reply With Quote
Old 10-18-2011, 09:35 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: How to grease speedo?
ive always shot WD40 down the cable and into the speedo with good results
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-18-2011, 09:47 PM   #3
chrohm
thanks, didn't know if I needed to use something 'special'
Old 10-18-2011, 10:42 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
i beleive ive heard of a kit that has a zerk adapter that screws onto the top of the speedo cable so you can grease it
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-19-2011, 12:45 AM   #5
bigwheel15
bigwheel15's Avatar
Graphite works as well.
bigwheel15 is offline   Reply With Quote
Old 10-19-2011, 07:14 AM   #6
BigBlocksRule
WD-40 is NOT a lubricant, it's a water disperser. If it helps, it's probably because it washed some sludge, etc. out. You can buy special speedo cable grease, the newer stuff is graphite and works better. I like the idea of a zerk but haven't seen that trick.
BigBlocksRule is offline   Reply With Quote
Old 10-19-2011, 06:01 PM   #7
raceman6135
Dino burner
raceman6135's Avatar
raceman6135 is offline   Reply With Quote
