Decided On a Motor.....Now Just Gotta Find One
SO I know I've been Pretty Much Decided On a 5.9 Cummins but after alot of Consideration and wellllll Comin on one in Craigs List.... My Mind Got To Churnning, I've decided, And I KNOW there's ALOT more Work involved.......... But i'ma go with a 6.7 Cummins, Same 6speed Manual Tranny... Always Was told if your Gonna do it do it Right the first time and you'll save yourself ALOT of head&heartache down the line So yeah.... the motors gonna cost quite a bit more.... My Question is Does Anyone out there Got Experience With Insurance Auctions??? Like Wrecked Cars & Trucks... Cause thats where I think I'ma end up with a motor from.... and depending on the condition of the frame... I may just do a body swap lol
Eric "Target" Sherwood Professional Bullfighter For Hire God Bless and Gods Speed! TheCowBoyProtectionUnit@yahoo.com http://www.facebook.com/pages/Eric-T...59496227444241 |
Re: Decided On a Motor.....Now Just Gotta Find One
Why a 6.7? why not just a common rail 5.9, or put the money into a 12 valve. If get a wrecked truck a body swap may be easier imo, there will be alot of wireing to deal with. What type of front suspension do you want, leaves or coils. Maybe the canadian frames i get are weaker, but they seem to flex alot so if you put in 1000lbs of engine the stock chevy frame would require tons of mods in my opinon.
Please correct me if I'm misinformed, isn't a 6.7 a larger 5.9 with more emmision bs? Anyway curious to see something happen in this way of a build... |
Second Chance Program
Also curious to see your reasoning.
6>8 Plugless........
![]() Join Date: Sep 2007
From everything I've heard of and the cost involved with the 6.7, I'd just do a 05-07 5.9 CR personally. I know where there is a 08 6.7 for $4500 complete engine if you want. The 6.7's can make good power and you can spool a 66mm turbo with a good tuner, but if it ever has problems, parts are more money and not as available as the 5.9's.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
6.7 or 5.9 CR all require A LOT of electronics.... 12 Valve only requires 3 wires.....or a choke cable if you want to go that route.
97 Dodge 2500 12V NV4500... way to much to list. 79 Chevy K20 4" RC/37" GY OZ's 350/465/205.... restoration somewhere in the futue.... NEW: Project 88 Chevy R3500 3+3 / 88 V3500 3+3 combing two to make one.... |
Emmisions aren't a big deal here Nebraska, the reason I'm lookin at a 6.7 is mainly mileage.... I plan I pullin 10k in beef not including trailer, routinely an everything I'm findin is sayin the 6.7's are pullin better mileage.... Also this truck is gonna be an update restoration...... Kinda a truck version of a Barry's Speed Shop Show that used to run on Discovery Channel
Now I'm curious, people claiming good mileage, do they have turners with egr dpf delete? I've heard alot of guys cursing the 6.7 for poor fuel economy.
I Just Want the Challenge Mainly... Something I can Call Completely Original
6.0 powered square
Just to let you some of the parts for 6.7 are almost double the price of 5.9 cw, I believe I saw a retail price of one injector for a 6.7 is a grand
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
yeah I know that...... I Dunna... its Just So enticing..... but the simplicity of the 5.9 has its benefits....... Grrrrrrrrrrrrrrrrrrrr Three Wires Is Great...
The 06 up 5.9 CR has more than 3 wires to hook up, just an FYI. Any common rail is going to be more expensive, just plan on it.
Same thing I've heard. Then the owners spend at least $1500 to get it where they're happy with it.
I Just Dunna.... the 5.9 is prolly the way I will end up going just due to the cost and lack of 6.7's around.... But I'm the Type of guy that will always wonder "What If" if i don't go with my heart and original idear (The 6.7 Route) .... Plus I want this to be a learning experience when I do it.... and I was planning on putting money into it to make sure it was were I wanted to be with Either Motor... its just a dream at this point though cause I have to get all the 4x4 Parts and the motor and wirin BEFORE I do anything, cause I'll be Doing it all at once
You should start writing down the cost for all your parts so you have an idea what you're going to be spending. And as far as wiring, I'm guessing you'll have to do that because I don't believe Painless has a kit out for the 6.7's yet. I'm guessing you'll have a mini stroke when you do it.
#15 |
LOL yeah.....Thats Just It... I Gotta Figure Out everything needed to do both.... First I Gotta Sell My Motor LOL, I've Got the Dana 60 for the 4x4 Conversion but I need all the other Parts for that....its Just a pick a part Up as I go here an there as I go while I save for the the motor....
#16 |
Which D60 do you have? Keep in mind that you will need to use a NP205 from a dodge, or a weak NP208 from a chevy, or re-clock any other tcase to use a GM D60.
#17 |
I'll have to look.... it was one from a Scrapper... he had a bunch but this one's missing somethings
#18 |
If it's a RH drop it's more than likely from a chevy or a pre 94 dodge.
#19 |
drop??
#20 |
Drive shaft drops on the RH side and feeds in to the diff.
#21 |
where the Pumpkin's at? cause yeah thats at the right hand side
#22 |
Yes sir. That's a RH drop. 94 up dodge are all LH drops. Just figured I'd let you know so you can plan according.
#23 |
hmmmmmmmmmmmmmmmmmmmmmmm...... I'll have to try an think this through now
#24 |
If you are having problems finding a 12 valve you ain't looking in the right places.Most of the 90s big fords f600 had a 12 valve in them the blue bird school buses the flat front end ones use it also.
#25 |
Round Here The Decent ones Get snapped up pretty quick and the flat Front School Buses aren't here.... its all Straight Truck style not cab-over.... i've Found Multiple partials but by the time I Spend buying partials to put one together I'll have spent that money in a decent 6.7
