10-20-2011, 06:48 PM | #1 |
Help with weather stripping
If anyone has the time and know how i need some help with weather stripping. I spent some time today trying to put the new stuff in my 67 c10 with the adhesive but i couldnt get it to sit right. if anyone can tell me the right way to do it and has some good pictures of how it should look all through the door jamb it would be great. thanks a lot.
10-20-2011, 06:58 PM | #2 |
#16876
Re: Help with weather stripping
I used blue painters tape to hold the weatherstrip in place while the 3M adhesive cured. Not sure if it's the proper way but it worked out good for me.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
10-20-2011, 08:54 PM | #3 |
Active Member
I worked top to bottom - lay it out and cut in near length but a little long.
I used chip clip clamps (the kind used to close potato chip bags) run a section clamp it and give it a chance to dry. Make sure that you use good 3M sealant. You can also use Binder clips that can be bought at an office supply store
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
10-20-2011, 09:05 PM | #4 |
I am a Referee of life.
I did the same thing as 68,except I used the cheapo clamps from HF.It takes it a while to set up.Less time when warm than cool.I use the Black 3M.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-20-2011, 09:23 PM | #5 |
Got big-block?
I tore pieces of blue tape and put them in place about every 3-4 inches, then just folded them over the rubber as I worked my way around the door opening.
SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
