Old 08-20-2003, 12:10 AM   #1
OneMpg
How to get hood to sit down . . .
I just bought my '70 chevy a few weeks ago and it has come time to start tweaking it to perfection. The first thing that bugs me is that the panel fit is really good . . . EXCEPT =) for the hood. The back of the hood is kicked up maybe 3/16s or a quarter. I talked to someone and they said that this can be caused by worn spring mechanisms. It seems like that could be true, but it also seems like it should be adjustable. Is there some way to adjust the hood? What is the best method? Thanks very much =)
-Dave-
OneMpg is offline   Reply With Quote
Old 08-20-2003, 12:42 AM   #2
miket
miket's Avatar
I always thought it was the hinge/spring.....mine is doing that too and I need to get it fixed.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 08-20-2003, 12:43 AM   #3
JHickson6
I Love This Stuff!
JHickson6's Avatar
Welcome to the board! Lets see some more pics of your truck, we'd love to hear all about it! In a 33 year old truck the springs are well past there prime, and do stretch out. It may be the culprit, plus there not to expensive to replace. just my 2 cents
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 08-20-2003, 12:46 AM   #4
rickspickuppart
it is the hinges they are probably worn out
rickspickuppart is offline   Reply With Quote
Old 08-20-2003, 12:46 AM   #5
rickspickuppart
the spring only helps you open it not to close it
Old 08-20-2003, 12:48 AM   #6
jhwkns
Registered Cruiser
jhwkns's Avatar
Before you try to adjust anything lubricate the hinges really well... really really well... chances are that's all it needs... If that doesn't work try loosening the bolts that hold the hinge to the inner fender, and knock it down a bit.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 08-20-2003, 12:56 AM   #7
rickspickuppart
remember wd40 is your friend
Old 08-20-2003, 01:24 AM   #8
Blue4x4
Blue4x4's Avatar
loosen the rear bolts of the hinge, and push the rear of the hinge down. If that doesn't work.......buy new hinges.
Blue4x4 is offline   Reply With Quote
Old 08-20-2003, 01:29 AM   #9
tripp
i have the same thing happening to my truck. the springs were just fine before i took the hood off, however it now looks like yours. unfortunately i had to mount the hood by myself, but i believe i had read a post before that said you should loosen the bolts holding the hinge to the fender and have a friend push up on the hood as far as possible and retighten those bolts while friend is holding the hood. it just may work. i'll let you know if it works.
68 SWB Stepside
72 Cheyenne 20
72 SWB Fleetside
72 Suburban
72 2wd Blazer
tripp is offline   Reply With Quote
Old 08-20-2003, 01:34 AM   #10
OneMpg
Thanks much for the welcome. =) Thanks for the info too. I'll try to write up an intro for my truck tomorrow when I'm not so tired. Here are some pics of it for right now. 4x4 Thread
-Dave-
Old 08-20-2003, 08:51 AM   #11
Huck
Huck's Avatar
ONE MORE TIME~~~~~~~
loosen the 3 bolts on each hinge where it mounts to the fenders. Then have a friend push the hood up till you reach the end of the hinge travel---then push it up just a wee bit higher---then tighten those hinge bolts. Make sure you don't just close the hood without checking the front to rear alignment as this method does tend to move the hood back a bit but it will bring the rear of the hood down even with worn hinges. Make sure you lube the hinge pivot points and keep them lubed---I use white lithum greese. Good luck ---Huck
Huck is offline   Reply With Quote
Old 08-20-2003, 09:49 AM   #12
72MARIO
72MARIO's Avatar
New hinges will fix it. Try and make sure they are lubed
If you take the springs off you will find that the hood will sit down in the back. So Make sure that the hinges are lubed up try that first before you make any adjustments.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-21-2003, 10:49 PM   #13
pa_snowman
yes make sure the hinges are lubed, this is often neglected. then to check to see if your hinges are worn close the hood and gently push down on the back of the hood. if it goes down and stays you should replace the hinges because the rivots are worn out from too many years of no lube. mine did the same except before i discovered it it wore clear thru and belive me that hood is heavy when it drops and you aren't expecting it.
if it doesn't stay simply adjust them.
jim gallagher
pa_snowman is offline   Reply With Quote
Old 08-21-2003, 10:58 PM   #14
onelow69
onelow69's Avatar
New hinges fixed mine. And like they all say lube real well.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect.
onelow69 is offline   Reply With Quote
Old 08-21-2003, 10:59 PM   #15
miket
miket's Avatar
I lubed and need new hinges...good time to paint!
Old 08-22-2003, 11:36 PM   #16
OneMpg
Thanks everyone. =) Lubed the hinges and it's much better now. That was easy, I thought I was going to have to do some adjusting or replacing
-Dave-
Old 08-23-2003, 02:56 AM   #17
Phillip Johnson
Phillip Johnson's Avatar
2 fat chicks and some wd-40....then 1 gallon of bondo to fix the dimples from your helpers..
I like the new hinge idea
Phillip Johnson is offline   Reply With Quote
