Old 08-19-2003, 11:32 PM   #1
Jemost 72
Southern Bowties
Jemost 72's Avatar
What will remove overspray?
Got my truck back from the paintshop, had interior/exterior done. He got a little overspray on the chrome around the gauges and on the instrument panel lense(factory dash). Any suggestions on how to get it off without scratching?
Pics to come soon, gotta finish interior this weekend...
1972 Cheyenne 350/350
Jemost 72 is offline   Reply With Quote
Old 08-19-2003, 11:40 PM   #2
Southpa
Southpa's Avatar
How fresh is the overspray? If the paint was sprayed w/in 24 hrs it could be rubbed off with acetone. If its fully cured it will be tougher. Hold a rag soaked with acetone on the area and the paint might soften up after 15 minutes. There are stronger solvents like MEK (methyl-ethyl ketone) that might work but it can be dangerous stuff.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 08-20-2003, 12:12 AM   #3
bowtie
bowtie's Avatar
paint remover
The autobody uses a product called "gun wash", it's used to clean their spray guns of course. I use it all the time to clean up overspray.
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick"
~72 chev swb w/68 front clip "GM Millenium corvette yellow"
I use and accept Paypal
bowtie is offline   Reply With Quote
Old 08-20-2003, 12:31 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
I don't think you want to put any solvenst on the lens. Probably not on the chrome either. Why not try a clay bar? It's non-abrasive, and has to be safer than any solvents...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-20-2003, 12:57 AM   #5
jhwkns
Registered Cruiser
jhwkns's Avatar
Have you tried soap and water?
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 08-20-2003, 01:04 AM   #6
rickspickuppart
if all else fails get a new bezel for 25$
rickspickuppart is offline   Reply With Quote
Old 08-20-2003, 01:09 AM   #7
Blue4x4
Blue4x4's Avatar
for getting overspray off chrome....use # 0000 steel wool. Can be bought at the Home Depot in the paint section. #00 is rated for polishing metals, but 0000 is much finer. Good luck.
Blue4x4 is offline   Reply With Quote
Old 08-20-2003, 01:39 AM   #8
tripp
i agree with n2trux. you would be amazed at how the detailing clay removes surface contaminants including overspray. i love it.
68 SWB Stepside
72 Cheyenne 20
72 SWB Fleetside
72 Suburban
72 2wd Blazer
tripp is offline   Reply With Quote
Old 08-20-2003, 11:25 PM   #9
Jemost 72
Southern Bowties
Jemost 72's Avatar
Thanks for the responses...I had a clay bar that I forgot about, took guage panel apart, cleaned everything, then used the clay bar on the lense and chrome around guages...looks new again! Thanks again!!!
Old 08-21-2003, 08:01 AM   #10
smokekiki
Mike
smokekiki's Avatar
Amazing what those clay bars do!
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-21-2003, 08:23 AM   #11
casey
casey's Avatar
whats a clay bar??
casey is offline   Reply With Quote
Old 08-21-2003, 08:46 AM   #12
smokekiki
Mike
smokekiki's Avatar
You can get them at any parts store where the waxes are.It is a clay bar and some spray lubricant.It will remove contaminents on your paint.You will be amazed at the dirt that comes off your paint.The wax job will look real good if you use the clay first.
Old 08-22-2003, 10:45 AM   #13
Brad
Out of the carpool lane.
Brad's Avatar
Clay bar's kick a$$!!! I just discovered this trick about 2 months ago. It took me several hours to go around my Camaro the first time, but now I just use it for touch up when the finish feels rough.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
