Old 10-21-2011, 02:17 PM   #1
markeb01
Senior Enthusiast
markeb01's Avatar
Grocery bag containment tip
Here’s a tip some may find helpful. I’ve never been very fond of taking the truck to the grocery store, loading everything in the back, and getting home to discover a jar of mayonnaise, jelly, or bottle of milk went flying across the bed. I’ve tried a variety of cargo restraints both when I had an open bed and a hard cover in place. Spider nets seemed too clumsy and straps or cargo nets never seemed to hold the items where they were convenient. Here’s a very simple method I stumbled upon to hold grocery bags right where I want them next to the tailgate.
Years ago I replaced every other fender bolt with a same size hardware store eyebolt. These required no holes to be drilled, and have proven immeasurably handy for tethering loads. Quite by accident I left a pair of long ball bungee cords in the eyebolt closest to the tailgate, on both sides of the bed. On the next trip to the store, it occurred to me to simply pass the bungee through the “handles” of the grocery bags and stretch the open end to the next eyebolt. It takes about 2 seconds to hook up or disconnect and holds everything in place in an upright position.
If you actually use your truck and don’t mind having a couple of eyebolts installed, it’s a very simple alternative to cleaning up splattered contents from the bed.
The photos aren’t very good, and the bed looks awful, but the pictures do tell the story. Here’s the passenger side of the bed showing the eyebolts:
Here are the ball bungees I just leave hanging in the eyebolts:
And here are grocery bags tethered to the bed wall. The bungees don’t show up real well being black against a black bed, but they stretch from the blue balls at the rear through the bag handles and loop over the forward eyebolt:
Old 10-21-2011, 02:31 PM   #2
MusicMan70
MusicMan70's Avatar
Re: Grocery bag containment tip
Great Tip. Nothing worse than stuff sliding and rolling around back.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 10-21-2011, 03:00 PM   #3
Clyde65
Clyde65's Avatar
Do you work for Walmart? Just asking....
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-21-2011, 03:04 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Nope, I'm retired. I just shop there because it's cheap and not too crowded it you're there a 6:30 in the morning.
Old 10-21-2011, 03:12 PM   #5
fattyarbuckle
Great tip!
Thanks for sharing....
fattyarbuckle is offline   Reply With Quote
Old 10-21-2011, 03:22 PM   #6
Bears63
...just another truck junkie..
Bears63's Avatar
I really like that idea with the eye bolts. I will have to remember that when I get to that point on my C20.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 10-21-2011, 03:56 PM   #7
vin63
It's Better With Nitro
vin63's Avatar
Cool idea. I started using a Rubbermaid tub awhile back and then tying that secure since it has handles. The worst I had was a corn oil incident...that stuff was murder to clean up.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-21-2011, 05:56 PM   #8
jimmydean
jimmydean's Avatar
I run a bungie cord between the front most stake pockets (the hole in the bottom of the pocket) and loop the handles through that. I like the eye bolts.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
