Old 10-09-2011, 10:04 PM   #1
dragn91
dragn91's Avatar
are factory auto truck rears geared better or worse for highway
Wanted to know if I should snag the rear out of an automatic parts truck to get better highway gears in my stick truck or would it be worse? She use to tach up pretty high on the interstate
dragn91 is offline   Reply With Quote
Old 10-09-2011, 11:57 PM   #2
jocko
jocko's Avatar
Re: are factory auto truck rears geared better or worse for highway
that's a good question - to the best of my knowledge, 3.08 and 3.73 were what was available, but I always forget what was standard and what was the option. But I do believe both were available in auto/manual trans trucks - so the bottom line is it really doesn't matter what trans is in the truck/car that you're considering nabbing the rearend from, what matters is strictly the actual rear end ratio in the vehicle you're considering grabbing the rearend from. If your manual tach'ed up, am guessing you had a 3.73, or perhaps a 4.11 (was that an option also or am I mixing it up with the AD trucks!?).
Old 10-10-2011, 12:57 AM   #3
Captainfab
60-66 Nut
My '66 Suburban was an original 283, powerglide burb, and the rear had 3.73 gears.
I agree with jocko. first you need to know what gears you have now, and then pull some covers to find the gears you want.
Old 10-10-2011, 01:04 AM   #4
oem4me
I believe the 3.73 was given to all trucks where none was specified.
Old 10-10-2011, 01:56 AM   #5
jocko
jocko's Avatar
that rings a bell in my brain housing group oem4me - thanks, I believe that is correct - the "option" was the 3.08.
Old 10-10-2011, 10:05 AM   #6
Wrenchbender Ret
Generally the auto trans rear ends were geared higher & are better for the high. Like the guys say you have to find out what you have & what the donor is & go from there.
Wrenchbender Ret is offline   Reply With Quote
Old 10-10-2011, 02:16 PM   #7
DBear
DBear's Avatar
Does this apply to 3/4 ton or 1/2 ton? I have a '62 3/4 that came with 283/ powerglide. Curious to what it has in the rear also!
DBear is offline   Reply With Quote
Old 10-10-2011, 07:28 PM   #8
chemlab
chemlab's Avatar
my experience with original rear ends is they top out around 55 on the freeway with todays speed limits. back in 66 the limits was much lower so the ratio matched the speed.
this page might be of use to find out what you want based on tire size after you find out what you currently have.
chemlab is offline   Reply With Quote
Old 10-11-2011, 12:33 AM   #9
Captainfab
60-66 Nut
I'm thinking the GMC would likely have a Dana 60 rather than the Eaton HO52, so it's hard to say. You might be lucky and have the 3.54 gears. If you do have the Eaton HO52 you will have either 4.11's or 4.57's.
Old 10-11-2011, 12:43 AM   #10
DBear
DBear's Avatar
The 62 is a chevy! What's the best way to id rear?
Old 10-11-2011, 12:46 AM   #11
Captainfab
60-66 Nut
Ooopps, I just looked at your sig and saw the GMC.
I don't have a pic handy, but the Eaton HO52 has a perfectly round rear cover with a fill plug. It also has the drop out 3rd member on the front side.
Old 10-20-2011, 08:34 PM   #12
DBear
DBear's Avatar
Captain, here a couple pics of my rear end, thought maybe you could help ID it for me...thanks bud
Also, didn't mean to hijack thread....
Old 10-21-2011, 12:53 AM   #13
Captainfab
60-66 Nut
Yep, that is a Eaton HO52. If you're lucky it will have the 4.11 gears. If not it will have 4.57 gears.
Old 10-21-2011, 06:06 PM   #14
Surfdaddy
Surfdaddy's Avatar
My 61 3/4 ton with a Hydra-Matic has 410's but that was ordered that way. I really need to get something like 323's or something for better highway driving
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 10-21-2011, 11:38 PM   #15
collins10672
collins10672's Avatar
while i am not 100% sure without looking in the spec book i don't think the 3:07 rear end was available with the powerglide.the 3:73 was.the 3:07 was available as an option with the 3 speed.my father had an original 1964 chevy short fleet with the 230 6 cylinder,3 speed and 3:07 rear axle and it ran really well out on the highway.it would cruise at 60-65 mph all day long and was really easy on gas too,but gas was only .80 per gallon then lol.
collins10672 is offline   Reply With Quote
Old 10-22-2011, 01:22 AM   #16
likaroc13
Rollin' Old Skool
my '66 previously had 3.73's....we swapped in a '72 rear with 3.08's for better highway driving...but the truck originally had a 283/Powerglide combo, and the PO swapped in a 327
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 10-22-2011, 06:17 AM   #17
tincan1966
tincan1966's Avatar
My 1969 C-30 had the Eaton HO72 with the 4.57 gears top speed- about 50! LOL! Just swapped out for a newer, but not as strong, corporate 14 bolt with 3.73 non locker. Highway driving is much more pleasant and the 427/TH400 doesn't have it's tongue hanging out after a trip down the highway.
tincan1966 is offline   Reply With Quote
Old 10-22-2011, 08:21 AM   #18
6flee3
6flee3's Avatar
63 C10, was a 6cyl, 3 on the tree ... had 12bolt with 3.73's
6flee3 is offline   Reply With Quote
