Old 10-21-2011, 07:41 PM   #1
natechevy72
natechevy72's Avatar
mini starter problem
I put on my mini starter and only used the purple wire like I have heard to do but the motor wouldn't turn over. I have a new wiring harness built to use a HEI with. Also I do not use the yellow wire right? What am I forgetting.
natechevy72 is offline   Reply With Quote
Old 10-21-2011, 08:22 PM   #2
72lb4x4
Re: mini starter problem
Starter doesn't turn, or the engine won't start?
72lb4x4 is offline   Reply With Quote
Old 10-21-2011, 08:44 PM   #3
natechevy72
engine won't start
Old 10-22-2011, 07:04 PM   #4
airdale94
airdale94's Avatar
Try switching the purple wire to the other small terminal if it has one.
The yellow wire is for points ign. HEI wire goes directly to distributor.
airdale94 is offline   Reply With Quote
Old 10-22-2011, 10:08 PM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
get a test probe or test light and check the wires and grounds too
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
