Old 08-20-2003, 12:25 AM   #1
chevychic
chevychic's Avatar
Question Steering Wheel Help (Horn)
When I first got my truck, the first thing I did was replace the old nasty steering wheel with a Grant. Well, it wasn't me, it was my husband and his friend. His friend had the tools and they got all gung ho and replaced the steering wheel while I was in the house. All was fine until the center cap popped off at 3 AM in the morning causing the wire to connect and the horn went off insistently. So my husband went out and wrapped the wire with tape to shut it up (hey, it was 3 AM in the morning...I wasn't moving )
Well a year later, I need my horn. People are being really stupid and I'm tired of using hand gestures to get my point across.
I downloaded the installation instructions from Grants website but it's not helping me any. I have one wire that comes out of the column and one connector on a retainer type piece....looks like a donut with three holes that loosely mount over the screws in the steering wheel. The top of this piece is a tan, with the back being metal. The connector for the wire is on the top. There are no connectors on the horn button. The spring is very touchy and comes off if the horn button is removed.
If I connect the wire to the connector, I get a clicking sound when I make contact from the back of the retainer to the steering wheel.
Can anyone tell me what I need to do to get my horn back?
This is what my steering wheel looks like:
ChevyChic
86 Chevy K-10
If I can't be a good example, then I'll just have to be a horrible warning.
"You're braver than you believe, and stronger than you seem, and smarter than you think"
- Christopher Robin
chevychic is offline   Reply With Quote
Old 08-20-2003, 08:35 AM   #2
BigRed
I wish I could help, but I bought a different wheel that had a different horn kit. My horn button has a two connectors on the back of it. No spring involved, so makes it nicer. I remember having that same wheel that you have on an old Ford truck and having shorting problems with the horn. Never did get it right so I installed a remote horn switch on the dash.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 08-20-2003, 11:05 AM   #3
chevychic
chevychic's Avatar
The clicking sound is the relay as my lights dim slightly when I honk my horn, so I know it's getting electrical current.
I'll look into a different relay. Now, can you tell me where the relay is located?
ChevyChic
86 Chevy K-10
- Christopher Robin
Old 08-20-2003, 11:39 AM   #4
dubie
dubie's Avatar
I have the same steering wheel in my 72. But to avoid the dreaded Grant GT horn problem, I re-routed the wiring to a separate button on the dash for the horn. I know that making a separate button for the horn isn't for everyone, but my truck is no show winner
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
