Old 08-20-2003, 11:49 AM   #1
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
TH350 Vacuum line HELP
HELPI rebuilt my TH350 at the end of last summer and it never shifted into 3rd properly. Last night was the first time I've had a chance to really test it out (we had a baby in January). It appears to be shifting into third if I'm not giving it any gas. When I step on the gas it shifts down to 2nd and won't shift up again until I start coasting again. I think it might be a vacuum line issue. right now, the vacuum line to the tranny is going to a port in the Edelbrock Performer intake manifold - the same one as the power brake vacuum. I switched it there because someone told me that is where it should be hooked up. Before the rebuild, it was attached to the carb (quadrajet). Where should the vacuum lines all be hooked up? I don't have a vacuum gauge. I really want to drive my truck again before the weather turns to rain
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-20-2003, 11:56 AM   #2
jose
jose's Avatar
Sounds like you have a vacuum leak or the rebuild wasn't done properly .
68 GMC 4x4 SWB
jose6772@yahoo.com
jose is offline   Reply With Quote
Old 08-20-2003, 12:03 PM   #3
tom hand
CCRider
tom hand's Avatar
Have you ajusted the detent cable properly?????????
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 08-20-2003, 12:47 PM   #4
jhow66
jhow66's Avatar
Make sure the vac line is hooked to vac. modulator-if not modulator is bad.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-20-2003, 12:48 PM   #5
tom hand
CCRider
tom hand's Avatar
If the modulator was not getting vacuum it would never shift out of first
Olive Branch MS
Old 08-20-2003, 12:48 PM   #6
jhow66
jhow66's Avatar
Sorry that should that should read "if it is".
Old 08-20-2003, 01:17 PM   #7
bouncytruck
SKINNY TIRES RULE!
Vacuum modulator is brand new. It appears to be working because I adjusted the shift point last night and it is shifting sooner. The detent cable is disconnected from the carb right now because I thought it was stopping the tranny from shifting. The line out from the vacuum modulator is a rubber line. I have it zipped tied away from the exhaust. I made sure it doesn't have any sharp bends or kinks in it. I know the truck is shifting into 3rd when I let off the gas because i can put it down into 2nd and feel it drop down - same going into 1st. It is just holding in 2nd when I am on the gas - even slightly.
bouncytruck 1972 K5
Old 08-20-2003, 02:43 PM   #8
COBALT
COBALT's Avatar
Vacuum should be full manifold vacuum, so in other words you have it connected correctly.
You know this may be a governor problem. Did you rebuild the governor when you did your rebuild? Remember that it helps determine shift position based on its counter weights, and how fast it is spinning (RPM).
As far as the rebuild goes...
When you re-assembled your valve body did you make sure to include all the right seals? There are some pressure checks you can do to verify that the appropriate fluid pressure is being applied whenever the gear selection has been changed. You probably should have done that before it went back into the truck. Whenever RPM is high enough modulator vacuum is supposed to help shift into 3rd and not hinder it. Almost sounds like the vacuum is trying to prevent the 3rd shift. This would lead me to believe that the valve body isn't translating the vacuum-to-fluid-pressure to indicate a 3rd shift correctly, or a bad seal is allowing fluid pressure to drop...
Just thinking...
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-20-2003, 03:14 PM   #9
bouncytruck
SKINNY TIRES RULE!
Cobalt, thanks. Not what I wanted to hear, but thanks. I guess I may have to drop the tranny/t-case again. I may just have to find someone to do this for me. I was hoping that it was just a simple vacuum line issue, but it sounds like it may be my inexperience in rebuilding the tranny. Anyone know a good (inexpensive) shop?
bouncytruck 1972 K5
Old 08-20-2003, 03:31 PM   #10
COBALT
COBALT's Avatar
Good question. I've been see-saw-ing back and forth on whether or not I want the 400 out of my daily driver taken to a shop, but I think I'm going to rebuild the one I got from WES and the one I got from breeh before I tackle my daily driver transmission...
Let me know how things work out...
Seattle, WA.
Old 08-20-2003, 04:01 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
This is incorrect. It will shift, but not untill you hit 5500 or so RPM. The tranny has a govenor that forces a shift regardless if the vac line is on, or even if you have the shifter in first gear, you spin it high enough, it WILL shift. (asuming the govenor is in proper working order)
bouncytruck, try this. Drive down the street up to where you think it should be going into 3rd, then go about 5 or 10 MPH faster. Then take the shifter, and place it into 2nd, and told it there for a couple seconds. While maintianing the same speed, shift it into 3rd. It shopuld grab 3rd, and stay there untill you slow down. My vac line came off on my mod last winter and I discovered this trick. I drove it for a week untill all the slish was off the road before crawling underneath.
You have it plumbed properly, but improperly. (confused?)
The tranny mod DOES need full vac to shift early, but the brake booster is taking all the vacume.
Try moving the tranny line to another port on the intake, or if none are avalible, put it on one of the lowest ports on the carb. (below the throttle plate) It should shift fine after that.
If no ports are open for this hose, you can place it on an upper port, but shifting will occur at a higher RPM. You can compinsate for this my adjusting the modulater screw to shift earlier.
LEt us know what happens.
Old 08-20-2003, 05:01 PM   #12
bouncytruck
SKINNY TIRES RULE!
longhornmail - thanks, I'll give that a try tonight. Hopefully that will fix the problem!
bouncytruck 1972 K5
Old 08-20-2003, 06:58 PM   #13
COBALT
COBALT's Avatar
Hey that is a cool trick. It at least allows you to isolate the modulator out of the equation, which is what's standing in the way of determining if your rebuild is suspect.
Governors are easy to rebuild by the way. 4 bolts and the thing will turn out of the side of the case. It's at least worth checking to see if those counterweights gets stuck the farther it spreads out, which would indicate it's not operating properly at higher RPMs, or where 3rd gear might be!
Good luck.
Seattle, WA.
Old 08-20-2003, 07:34 PM   #14
Longhorn Man
I stumbled on that trick about 2 years ago when the hose came off. I had been shifting it manually and the hose popped off, so I had thought I was holding it in 2nd. I looked down and it was in drive...I don't know why, but I popped it down and back up and WOW. It shifted.
Went home and saw the hose off.
Old 08-20-2003, 08:01 PM   #15
crazy longhorn
Fabricate till you "puke"
Another thought, you do need rubber hose on ea end, but should be running a steel line (all but 6" ea end)......you may allready be set up this way.... good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-20-2003, 08:07 PM   #16
bouncytruck
SKINNY TIRES RULE!
I'm running a brand new all rubber hose. Should it be a steel line? What would the difference be? The kit did come with a short, pre-bent rubber line to run out of the vacuum modulator. I thought it was just so there were no kinks in the line. Should I use that and run steel lines up to the manifold?
bouncytruck 1972 K5
Old 08-20-2003, 08:07 PM   #17
Longhorn Man
Good point Al, if you have rubber, it can get sucked shut...actually collapse from the vacume inside. The longer the hose, the more likely it is to happen.
The stock hard line shoud start close to the back of the engine, and then the bottom end should only be about 6 inches of rubber line.
Old 08-21-2003, 11:47 AM   #18
bouncytruck
SKINNY TIRES RULE!
I'll pick up a new piece of line and give that a try too! Anything is easier than dropping that transfercase!
bouncytruck 1972 K5
Old 08-21-2003, 02:08 PM   #19
COBALT
COBALT's Avatar
...hmmm. I thought of this too when I threw away the horrible disfigured, and bent steel line I had feeding my modulator, but I had some reinforced rubber line small enough so I just rigged up some of that.
I might want to flare up a piece....
Seattle, WA.
Old 08-21-2003, 04:12 PM   #20
COBALT
COBALT's Avatar
Oh and another thing. A member reminded me of this site that has a pretty good message board for transmissions. I'm a member, but haven't been there for a while. Good place to ask questions about problems, rebuilds, and modifications:
Netgearhead.com
Seattle, WA.
Old 08-22-2003, 12:23 PM   #21
bouncytruck
SKINNY TIRES RULE!
Thanks again, I haven't had a chance to get out there and try any of the suggestions yet. Hopefully this weekend!
bouncytruck 1972 K5
