Closed Thread
Old 10-23-2011, 12:39 PM   #2976
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: What did you do to your truck today!
That's beautiful, Bennett. REALLY beautiful!
I've been diverted for a few days. Had to go pick up my newly built ride in Santa Cruz.
Lots to do on the truck. And winter's going to be closing in (again). But I'm only one guy.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-23-2011, 04:27 PM   #2977
Bennett68C10
Bennett68C10's Avatar
Thankyou I appreciate it
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 10-23-2011, 07:16 PM   #2978
72cummins
72cummins's Avatar
Got the power steering working two weeks ago. Replaced the front brakes this week and adjusted the parking brake.
Bryce
72cummins is offline
Old 10-23-2011, 07:53 PM   #2979
magwakeenercew2jh
Well, I did make it over to the shop today. Climbed under for the thirtieth time (still up on jacks in the front) to check the front brake line connection. New SS LMC lines. They don't send you a "T" with the "kit"....
.....So I am using the old one. Leak...leak...leak. Now I can't figure out whether there's a leak, or the brake fluid is some that I missed last time... that just hung on the coiled wire covers until I wasn't looking.
Maybe it was from the twenty-eighth time I was under there "adjusting" (tightening and adjusting) the lines. If there's any more fluid there next time, I'm going for a new "T".
Also, I got the speedo gear housing changed out. Since I'm chasing leaks, the trans needed some attention. With the advice of some Forum Members, I switched it out and wore a "clean suit" while I was under there.
If it's anything like the brakes, I'll be fussing around with it for another year before I feel the breeze in my face.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 10-23-2011, 08:28 PM   #2980
srvivor71
srvivor71's Avatar
Originally Posted by Bennett--G4L View Post
Bolted on some of my go fast goodies.
Gorgeous!
srvivor71 is offline
Old 10-23-2011, 08:36 PM   #2981
srvivor71
srvivor71's Avatar
FINALLY got my brake lights fixed! Turns out the problem was a bad turn signal switch. Between this and my never ending horn problems, I know WAY more about the steering column now than I ever dreamed of or wanted to. Oh, and if you are going to replace the brake light switch in one of these trucks, do it while you're young, before you get bi-focals and arthritis .
Old 10-23-2011, 10:14 PM   #2982
Bennett68C10
Originally Posted by srvivor71 View Post
Gorgeous!
Thankyou srvivor71
Keith
66 Suburban
IG: bennett68c10
Old 10-24-2011, 08:28 PM   #2983
glider_6969
Took it out for a ride, hasn't been out for a couple of weeks
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline
Old 10-24-2011, 10:58 PM   #2984
ChumBucket
1. Welded "fish plate" and strips where I cut down the LWB to make a SWB
2. Sandblasted the frame, UCA, LCA, rear end, control arms
3. Primed my porterbuilt goodies
4. Ordered my new wiring harness
5. Argued with myself (again) about which air management system to buy
6. Argued with myself (again) about which wheels to buy
ChumBucket is offline
Old 10-24-2011, 11:01 PM   #2985
RossRinSD
RossRinSD's Avatar
Do you have any pics of your shortbed conversion? Kinda interested in where you made the cuts and how exactly you did it.
1969 Chevy K10
1984 Chevy Monte Carlo SS
1998 Chevy Camaro Z28
2004 Chevy Silverado
2010 Chevy Colorado
RossRinSD is offline
Old 10-25-2011, 11:14 PM   #2986
AustinScott
AustinScott's Avatar
I tore the frontend apart... Installing power 5-lug Front Disc conversion
My son Removed the A-arms, & help me install the new power booster & front brake lines for mock up.
I'll post those picture later.
Scott
AustinScott is offline
Old 10-28-2011, 01:12 AM   #2987
allchevy58
allchevy58's Avatar
Had to replace fan clutch tonight after work. It was working fine, not loose or spinning free last week when I replaced radiator, all hoses and thermostat.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline
Old 10-28-2011, 07:04 PM   #2988
Mayo
Cool Truck
Mayo's Avatar
I installed my new led taglight today, the gauge lights are next.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline
Old 10-29-2011, 01:30 AM   #2989
allchevy58
allchevy58's Avatar
Had A/C recharged today. New hoses and fittings didn't leak, nice cold air again.
Old 10-29-2011, 07:42 AM   #2990
Steve Hafner
Steve Hafner's Avatar
After three LONG years, I finally got it back from it's restoration. We took it to a local cruise and it's now back in the garage where it belongs.
Now, I have to start doing all the "little" things that needed to be finished before it left !!!
Life is short . . . we only have, right now.
My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526
Steve Hafner is offline
Old 10-29-2011, 10:30 PM   #2991
re1
re1's Avatar
Took the old steel bumper off and put a new chrome one on,
the truck came from the factory with a chrome bumper so just getting it back to stock.
1972 Chevy C10 Custom Deluxe Highlander
1972 Chevy C10 Custom Deluxe Medium Green
re1 is offline
Old 10-30-2011, 12:50 AM   #2992
ItsRandy
ItsRandy's Avatar
Replaced the front panel in my bed. The old one was pretty bent from 40+ years of stuff sliding from the back and slamming into the front of the bed when ya' stomped on the brakes. Funny thing...the old bent panel fit better then the new Taiwan replacement. Go figure!
ItsRandy is offline
Old 10-30-2011, 01:44 AM   #2993
magwakeenercew2jh
My trimmed and crimped A/C hoses were back in my mailbox from Vintage Air.
Total of one week to turn around from San Antonio, TX.
Around here, there's no one to do the job right. Vintage Air knows some of us live "in the woods".
So they offer the cutting and crimping service free of charge.
Cost me ten bucks for freight...that's all. And it's done to my lengths....and to their specs.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 10-30-2011, 04:02 AM   #2994
project 67 sub
project 67 sub's Avatar
picked up my free spare 68 hood that i will eventually chop up and make a cowl hood scoop out of, and then i will eventually attach it to my hood current 67 hood
project 67 sub is offline
Old 10-30-2011, 06:23 AM   #2995
trev1
Installed the Radiator, Hold down clamps, front headlight buckets, battery box, hood,cowling and started to align the gaps in it all. What a job!!!!!!
I ran out of paint to black the clamps and the top of the radiator out. So they are just primed.
I just hope I dont have to take the front clip apart again.
Here are some pics.
trev1 is offline
Old 10-30-2011, 11:05 PM   #2996
bollybib
bollybib's Avatar
I drove it to the store at 7 am because I needed milk for my breakfast cereal.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline
Old 10-30-2011, 11:29 PM   #2997
74baggedbug
drove it to work & enjoyed it.... also had to show a dumb honda that there isnt anything like the sound of a v8
74baggedbug is offline
Old 10-31-2011, 11:38 PM   #2998
ItsRandy
ItsRandy's Avatar
Ordered my radiator today...$790.00 OUCH!
ItsRandy is offline
Old 11-01-2011, 09:29 PM   #2999
allchevy58
allchevy58's Avatar
What radiator did you buy? Yah OUCH!!!
Old 11-01-2011, 09:42 PM   #3000
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Ordered my No-Limit Engineering rack and pinion setup today! Cant wait to get it.
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline
Closed Thread
