Old 10-24-2011, 12:21 PM   #1
onequickchevy
onequickchevy's Avatar
Re: New guy new project
Cool start, nice to have another 63 added to the pile. Is there a harmonic balancer bolt on the 283 or is it press on? All early ones were press fit iirc, I had a nasty 283 in my 57 for a while, and we had to tap the crank snout for a bolt, it would work off at extremely high RPM's. Great engine for sure!
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 11-10-2011, 08:59 AM   #2
waspp
waspp's Avatar
The weather has be good and I was able to get one side of the cab floor all done with new pillar post, cab floor brackets and the rocker reinstalled. I sand blasted the frame under where the cab sits and primed and painted it so when the braces are all done I can set the cab down and have that part at least completed.I used the mastercoat silver primer and tractor coat top coat and really liked the way it sprayed and covered, time will tell weather it hold up but looks pretty good. A pic of frame with the silver primer before the black top coat.
waspp is offline   Reply With Quote
Old 12-25-2012, 02:58 PM   #3
waspp
waspp's Avatar
Some how I missed this post and just noticed it upon reviewing the thread. Sorry about that. Yes it has a pressed on balancer but while the engine was out we drilled and tapped the end of the crank and put a harmonic balancer bolt in from an 80's parts truck. I was worried about the same thing happening.
Old 01-04-2013, 05:44 PM   #4
waspp
waspp's Avatar
Finally starting to look like something. It's a great feeling to be bolting on new parts instead of removing old ones!
