Old 10-24-2011, 11:57 AM   #2301
landarts
landarts
Re: 67 cheby's Dropmember build thread
Nice detail on the raised bed. Im sure you will get a few followers on that technique. Great detail!
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 10-24-2011, 12:13 PM   #2302
67cheby
67cheby
67cheby's Avatar
thanks i appreciate it....they are in for ALOT of work if they do follow...LOL, or maybe i just overbuild and over complicate things !!
67cheby is offline   Reply With Quote
Old 10-24-2011, 10:34 PM   #2303
67cheby
67cheby
67cheby's Avatar
well i picked up all of the new 11 guage stuff today....here we go again !! marked it all getting it ready for cutting and tacking it together tomorrow
Old 10-24-2011, 10:41 PM   #2304
67chevy1series
67chevy1series's Avatar
thats the only disappointing thing about this build thread, not enough pics!!!! good work mike!
67chevy1series is offline   Reply With Quote
Old 10-25-2011, 07:30 AM   #2305
raull
raull's Avatar
good luck !!!!!!!!!!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 10-25-2011, 09:39 AM   #2306
Donnie Mabe
very nice is the front rear cross member stock if i had 4 wheel discs id be driving now instead of typing god bless
Donnie Mabe is offline   Reply With Quote
Old 10-25-2011, 09:58 AM   #2307
67cheby
67cheby
67cheby's Avatar
i will post some pics tomorrow.... of tonights progress , rebuilding the rear bed brace !!
Old 10-25-2011, 10:49 AM   #2308
superflysteiny
superflysteiny's Avatar
Nice detail I like it.
superflysteiny is offline   Reply With Quote
Old 10-25-2011, 10:59 AM   #2309
67cheby
67cheby
67cheby's Avatar
thanks man !!
Old 10-26-2011, 09:28 AM   #2310
67cheby
67cheby
67cheby's Avatar
very fustrated Mike here !! so i cut all of the 11 guage stuff last night and was mocking it up by tacking it all together, my plan was to tack it all together and then take it to my friends fabrication shop , get it clamped down on a welding table and finish welding it .....well it warped just tacking it together !! what the heck this is 1x3 tubing...how is that warping like that ? is it my crappy harbor freight mig welder ? or should i have had it clamped down even just to tack it together , or would it still warp even if it was clamped down ? the longest beads i ran were probably 1 inch long and about 4 inches apart from each other...i thought that would be ok on something this thick ?? any input ? it is only warped about 1/8 of an inch right now so i think i might be able to straighten that but i have ALOT more welding to do !!
Old 10-26-2011, 11:02 AM   #2311
watahyahknow
watahyahknow's Avatar
howbout heating it all up with a propanetorch before welding on a lower setting ?
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-26-2011, 11:33 AM   #2312
hotrod1
56 - autocross
hotrod1's Avatar
do u have all the welds on one side? If so alternate welding one weld on one side and then another. I all the welds are going to be on one side, good luck. You might just have to bend it back. Dont you just love metal some time?
hotrod1 is offline   Reply With Quote
Old 10-26-2011, 11:38 AM   #2313
67cheby
67cheby
67cheby's Avatar
i didnt alternate from side to side....but then again i thought i wasnt welding enough to get it that hot...live and learn i guess
Old 10-26-2011, 11:42 AM   #2314
hotrod1
56 - autocross
hotrod1's Avatar
more like opposite sides. This keeps the one side from pulling too much. I would weld one seam, turn it over and weld the opposite side. Then I would go to the other side of the project and do the some thing.
Try and do the same welds on the opposite side (turn it over). That may straighten things out for you.
Old 10-26-2011, 11:43 AM   #2315
big_al_71
big_al_71's Avatar
I wish there was something that I could say to contribute other than good luck and keep your head up you will get it right....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-26-2011, 11:55 AM   #2316
67cheby
67cheby
67cheby's Avatar
LOL.....thanks Al ...i am feeling the same way right now !!
Old 10-26-2011, 11:56 AM   #2317
67cheby
67cheby
67cheby's Avatar
thank you Hotrod1 i will try welding more on the other side tonight maybe it will straighten it back out....if not ..i guess off to buy another 45 worth of metal and start over AGAIN !!
Old 10-26-2011, 12:00 PM   #2318
trevorrhine
trevorrhine's Avatar
Definitely move around on the project to avoid getting one are too hot. I've used a damp rag as well to quench the area after I lay a weld to keep the area cool (sucks the heat into the rag), might be worth a shot to help prevent warping in your case...
1967 Chevy c10 SWB
Project "Daily Driver"
Build Thread:
http://67-72chevytrucks.com/vboard/s...ar#post4953311
trevorrhine is offline   Reply With Quote
Old 10-26-2011, 12:03 PM   #2319
67cheby
67cheby
67cheby's Avatar
thanks , i am looking for any suggestions like that , i will try about anything if it will help !!
Old 10-26-2011, 12:14 PM   #2320
trevorrhine
Be sure to use a crappy rag though because if it dries out a little too much, it'll burn some holes in it...
1967 Chevy c10 SWB
Build Thread:
Old 10-26-2011, 12:18 PM   #2321
67cheby
67cheby
67cheby's Avatar
so.....none of my wifes kitchen towels then...LOL
Old 10-26-2011, 12:24 PM   #2322
watahyahknow
close off on side make a little bend up on the other side and filling the tubes them selves with water , you prolly need to weld on a higher setting but the heat will spread less
Old 10-26-2011, 12:33 PM   #2323
trevorrhine
that sounds like a pain lol, plus the inside surfaces of the metal would likely get all rusty before you were finished. I like to keep everything as rust free as I can, that's why I like the rag trick...you don't have water going all over the place either.
1967 Chevy c10 SWB
Build Thread:
Old 10-26-2011, 01:08 PM   #2324
raull
raull's Avatar
hey mike i agree the guys , i use to weld 20 to 30 feet beams in rool forming machinery and the trick was to clamp and also change from side to side to let each side cool down and the kitchen towels also help ,
raul
Old 10-26-2011, 06:28 PM   #2325
68 TT
Still plays with trucks
68 TT's Avatar
Great idea to keep from chopping up a perfect tail gate.
Tack the whole thing together with it clamped down and cool it off with the wet rag after each tack to keep it in the shape you want then try only putting down a 1/4" of weld at a time and skip around on the piece cooling it off as you go. The longer the bead the more it will pull the metal out of shape when it cools.
It will take a bit longer to do but should keep it from warping out of shape.
Have you thought about more precise tail gate hinges so it can't shift side to side any and allow misalignment of the ribs between the bed extension and the tail gate? I would hate to see it shift a little to one side and chip your finished paint.
I want to put something together that uses greasable Delrin bushings so the tail gate is quiet when opened but it could also make it more precise in side to side location too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
