10-24-2011, 08:47 PM | #1 |
Headlight problems. Bad relay?
A couple of months ago I did the headlight upgrade adding relays to the high and low beam circuits. Everything worked great until tonight. I was driving down the road and my lights went out. Fortunately the high beams work. After a few minutes they would come back on but only for a few seconds.
I pulled over to have a look and everything looked fine. I could get them to come on by tapping on the relay. We'll see how long it lasts. Am I right in assuming I probably have a bad relay? Posted via Mobile Device
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
10-24-2011, 09:46 PM | #2 |
Re: Headlight problems. Bad relay?
I just finished the headlight relays on the old brown truck. I bought headlight relays and holders from a 90's Jeep Wrangler at a pick-n-pull. I bought the new locking spade clips and changed all the wiring to 10 gauge in the holder and then the relay would plug in the top. I spent 4 afternoons jacking with that damn thing because I had no high beams, bought a new dimmer switch. Finally chased it down to the relay holders, wires were coming out, loose in the holder (even though they were new locking clips) lights going off/on, etc. I finally cut it all loose, put yellow blade clips on the wires, no holders, and plugged straight onto the relays and all works well, Check to make sure you have good connections.
No one ever fell to the top of a mountain. When asked why I work on old trucks, I tell them: Been married 27 years, sons are pretty much gone, don't like the wife anymore and don't have a girlfriend, so, gotta do something, the old trucks are cheaper and less drama than a girlfriend - |
10-25-2011, 07:46 AM | #3 | |
This time buy two. Keep the spare in the glove box. The next time this happens on the road and you don't have a spare, swap the relays so you can drive home with your low beams on.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
10-25-2011, 11:11 AM | #4 | |
Thanks!
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
