Old 08-19-2003, 04:32 PM   #1
Wootdog
Wootdog's Avatar
Lokar shifters
Anyone ever purchased one of their automatic shifters for the floor? There are two different types I saw on the Lokar site that I am interested in. One is the one that has the exclusive lockout feature for shifting between park reverse neutral, overdrive, three two one, etc. This will be for a 4L60. It has shaft lengths of 6 to 23 inches.And the other is the one that can actually be mounted above or below the floor on the transmission tunnel. It has lockout feature for park and neutral only. It has shaft lengths of 12 or 16 inches. I was thinking the 12 inch would probably be the right one for a truck. They also have LED boots for either vertical to the left of the shifter or horizontal at the base of the shifter. Any comments? Thanks in advance Wootdog
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 08-19-2003, 05:45 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've used Lokar shifters in all my street rods. Cheapest place to buy them is usually Speedway Motors. Lokar rocks.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-19-2003, 06:56 PM   #3
cdowns
cdowns's Avatar
i've got one in my truck on my 2004R works good, just got another today from speedway for my model a. 12" is pretty short you'll be bendind down everytime you shift
Old 08-19-2003, 08:55 PM   #4
67cst
i love summertime
67cst's Avatar
i got a 16 inch on my th400, its perfect height, i mean PERFECT
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 08-19-2003, 09:29 PM   #5
Glen
I own four of them, I run the 23" swan neck in my 68 and it looks like an old 4 speed stick, comes right up to the dash.
It has a lot of adjustment on the cradle itself you can locate in different positions, and the entire shifter pivots back and forward slightly if you run into any other concerns for adjustment.
Glen is offline   Reply With Quote
Old 08-19-2003, 09:37 PM   #6
cnshoot
cnshoot's Avatar
do any of these fit through the high hump 4 sp hole
72 cst 2wd blazer sb soon to have tilt manual
72 gmc swb fleet 2wd bb air tilt auto
93 c/3500 crew-cab dually
03 chevy suburban LT quadrasteer c/2500 4x4
cnshoot is offline   Reply With Quote
Old 08-19-2003, 09:49 PM   #7
Glen
I cut a new hole thru my high hump 4spd hole then patched the old hole. I put the shifter where i liked it then mounted the cover.
Old 08-19-2003, 09:50 PM   #8
cnshoot
cnshoot's Avatar
that is what i was tring not to do cut my hump up i guess i could just buy another one
Old 08-19-2003, 10:13 PM   #9
cnshoot
cnshoot's Avatar
can we get some pics of these shifters i have been wanting to do this since i got a counsole
Old 08-20-2003, 08:54 PM   #10
polevault1977
Pick'n up the pieces!
polevault1977's Avatar
I'm thinking of going this route also. Pics would be nice!! Danny
polevault1977 is offline   Reply With Quote
Old 08-20-2003, 09:06 PM   #11
Tx Firefighter
Here is the one in my 54 Chevy. I think it's called the "Nostalgia".
