![]() Join Date: Aug 2004
Re: 66 C10 Disc brake booster question
Contact Captn Fab, get his mount and go to a wrecking yard and pull one off a 73-87 1/2ton truck, make sure the fluid looks good before you do and it is generally clean/serviceable. You will be out probably less than $150.00
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
60-66 Nut
Whether you buy a '71-'72 booster or the CPP booster/master combo, you will have to drill some holes to mount them to your truck. The booster bracket that I sell is a direct bolt on to the firewall. Then you bolt on one of the compatable boosters listed in the for sale thread, seen in the link below \/ \/ \/
