Transfer case help
Here's one. What type of transfer case came in a 1983 K30? I'm looking at buying a retired CDF truck with a 350,turbo 400, 14 bolt rear and a stout looking Dana 60 up front. Thanks in advance.
Re: Transfer case help
Should be a 205, but could be a 208. Is the case cast iron? In between the front output rear bearing support and the rear output, is there a little 3-bolt cover? If yes to these two questions, it is a 205.
Best bet is to take pictures of the T-case and post them. |
Grease Monkey
Pictures would be helpful. It would be a NP205 or NP203.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
like chevy said i should be a 205 or 203 like red said if its got a 3 bolt middle cover on the back its a 205 if not its a 203 and if its aluminium, which i doubt it is, its a 208 but more than 99% sure its a 205 or 203
82 k10 350sbc, sm465, np205, dana 60 front 14 bolt ff rear 4 inch susp lift 33's aka "MUD SLUT" 2007 cbr 1000rr ![]() |
Shouldn't be a 203 in an 80's truck. Most likely an NP205 in a 1 ton, but could be an NP208. I'm 95% sure it should be a 205.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
goggle pictures of them and discription, take that knowledge with u when u go look at the truck.
Chevys Kick A$$
I bet its a 205 since its behind a Th400. The easiest way for me to tell the 205s apart are that they have a fill plug and drain plug and the 203s only have a fill plug.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
The Man The Myth The Mystery
or you could just look at the shifter if you are debating a cast iron or aluminum transfer case.
![]() Join Date: Mar 2003
