Old 08-19-2003, 09:07 PM   #1
dinnut
dinnut's Avatar
lights?
alright, my 70 has something funky going on. if i put the left turn signal on, the front light doesnt blink. but when i put the headlights on it comes on... still doesnt work when turning left. my side lights are non existent ( no wiring or bulbs in or near them) any ideas. btw my truck still makes that banging noise when trying to start it. one day it started and we put a new starter after the bendix wouldnt extend far enough to reach the flywheel. so now after the new starter is on it spins enough to reach the flywheel and then makes a clanking noise. im thinking i got a funky flywheel. maybe the wrong size or something. anything would help.
also polished it all up couple days after these were taken. take more soon.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 08-19-2003, 09:08 PM   #2
dinnut
dinnut's Avatar
recent photos.
70 longbed
496/th400/Ford 9"
Old 08-19-2003, 09:24 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Sharp truck!. I bet it's the turnsignal!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-19-2003, 10:08 PM   #4
Jwill41
Jwill41's Avatar
sounds like ground is bad at one of the sockets.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-19-2003, 10:21 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Yep, sounds like you have a bad ground. The reason it comes on when you turn the headlights on, is because the turn signal light is reading a ground, thru the headlight bulb. So, here's one thing to check: The turn signal/park light housings probably have rust or other corrosion between the housing and the socket for the bulb. Another (easier to fix) problem is the failure of the bulb to make proper contact within the socket. NAPA has a tool designed to clean out the corrosion/rust, in a light bulb socket (with power off).
Check the wiring, to be sure the grounds are connected, and that they are "clean", i.e., not rusty or so forth. The wiring harness for the lights has all of the lighting connectors attached. Check all connections for proper make-up (male to female).
As for the side marker lights, believe it or not, they were just reflectors, when new. New wiring harnesses have the pigtails for the side markers, if you want to make them operable. I bought a new harness from www.wiringharness.com, which is M&H Electrical Fabricators, in California. Check them out, if you are interested in new harnesses.
My guess is that you will probably need new housings, because the corrosion between the socket and the housing will be very difficult to overcome....unless you can bridge them. Maybe a small sheet metal screw will tie the two parts, electrically. It's a long shot, but it might work.
Member Nr. 2770
Old 08-19-2003, 10:40 PM   #6
Jwill41
Jwill41's Avatar
Mine does that sometimes and I have to wiggle the park light socket on the front.
Old 08-19-2003, 10:55 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Have you checked the bulb?
Old 08-20-2003, 11:50 PM   #8
dinnut
dinnut's Avatar
the bulb works when i put on the headlights. so its not socket or bulb. on 69-70 the turn signal lights come on with the headlights in the front. but wont blink when i hit the thing to go left.
70 longbed
496/th400/Ford 9"
Old 08-21-2003, 12:02 AM   #9
Blue4x4
Blue4x4's Avatar
sounds like a bad ground.
Blue4x4 is offline   Reply With Quote
Old 08-21-2003, 12:27 AM   #10
Longhorn Man
Yes, but there are 2 filliments in that bulb...think of it as 2 bulbs in one.
If the dim one works, (parking lights) then that is one filiment. Then when you turn on the turn signal, the bright one works.
One can work and the other be dead.
Try taking the bulb out and swapping it to the other side.
Old 08-21-2003, 01:07 AM   #11
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I had the same problem with my brake lights on my fathers trailer, it turned out to be the bulb.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 08-21-2003, 02:21 AM   #12
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I had the same exact problem. tighten the bolts for the turn signal housing. It will fix the problem, or atleast it fixed mine.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
