Old 10-25-2011, 09:29 PM   #1
rs72z
rs72z's Avatar
ccsb questions
When you guys shorten your frame what do you do on the driveshaft?
Do you stay with a two piece or do you go to a one piece?
Also when installing mid 80's suburban seats do you need any brackets out of the burb other than the tracks?
rs72z is offline   Reply With Quote
Old 10-26-2011, 11:00 AM   #2
rs72z
rs72z's Avatar
Re: ccsb questions
anybody?
Old 10-26-2011, 11:44 AM   #3
volleyballer13
volleyballer13's Avatar
Re: ccsb questions
You will probably have to stay with a 2 piece drive shaft. Check with whoever is going to make or cut your drive shaft, but I believe if the drive shaft is going to be over 70" they recommend staying with a 2 piece. With a CCSB, yours should be over 70". Hope this helps.
volleyballer13 is offline   Reply With Quote
Old 10-26-2011, 11:46 AM   #4
rs72z
rs72z's Avatar
Re: ccsb questions
I was hoping i could use a 1 piece, guesse i will wait and measure it after i get the frame done.
Old 10-26-2011, 07:59 PM   #5
OJOE
Crew Cut
OJOE's Avatar
Re: ccsb questions
i used the 2 piece on mine, had to have the rear piece cut
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 10-26-2011, 11:16 PM   #6
rs72z
rs72z's Avatar
Re: ccsb questions
Thanks that's what i needed to know.
Thanks and i love your truck really inspired me to get started on one.
Old 10-26-2011, 11:32 PM   #7
SCOTI
SCOTI's Avatar
Re: ccsb questions
Swapping burb/blazer buckets into a truck that had a bench seat does require inner bracket stanchions to keep the inside of the bucket seat level w/the outside. These could be made w/some steel plate bent up to the right dimensions or you can knock-out/cut them off of the floorpan from the donor vehicle.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-27-2011, 07:47 AM   #8
rs72z
rs72z's Avatar
Re: ccsb questions
Thanks for the info.
Old 10-27-2011, 10:04 PM   #9
coxey26
Re: ccsb questions
i just cut my drive shaft down a few days ago, you cant go over 68"....i also am putting bucket seats in mine from a suburban. with the seats, i we just made some small brackets out of steel and bolted it to the floor..they hold up fine and look pretty good. do you have pics of yours?
coxey26 is offline   Reply With Quote
Old 10-28-2011, 09:04 AM   #10
rs72z
rs72z's Avatar
Re: ccsb questions
I only have one pic right now, going to pick the truck up Sunday. Po had to pull the bigblock out, i putting in a 5.3 and 4l60e. I'll post up some pics when i get in Sunday night.
