Old 08-21-2003, 08:27 AM   #1
casey
casey's Avatar
Question Whats the best way to store a vehicle???
Do you guys have any tricks on storing a vehicle, My son has to store his truck till next spring, its going to be parked out side.
casey is offline   Reply With Quote
Old 08-21-2003, 08:47 AM   #2
Hutch
Hutch's Avatar
casey,
I have never used one of these, but I have heard they work great.
http://www.classiccarcocoon.com/index.phtml
I would also like to see some more detailed pics of your truck.
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 08-21-2003, 09:24 AM   #3
casey
casey's Avatar
Hutch I keep threating to get a digital camera, I might borrow one and gets some pics up on the board, thanks for asking
Old 08-21-2003, 09:57 AM   #4
cdowns
cdowns's Avatar
if it's just short-term till spring just change the oil and filterfill gas tank with hi-test and add fuel stabilizer a good wash and wax and you'd be set
Old 08-21-2003, 09:57 AM   #5
cdowns
cdowns's Avatar
oh and disconnect and remove battery
Old 08-21-2003, 02:03 PM   #6
rickspickuppart
I know a guy that has a 69 pace car that uses a thing that looks like the bubble the bubble boy was in that movie, and dust doesnt even make it through. I am sure it won't last out side very long but I just thought I would let you know about it.
rickspickuppart is offline   Reply With Quote
Old 08-21-2003, 02:22 PM   #7
VTKidder
Anyone ever heard of parking the thing, and on the last shutdown of the year, get the revs up, and pour ATF down the carb til it chokes itself and stalls? I've heard of this being done; apparently does something for lubrication. Old wise tale or a practical storage tactic? (No, I won't try with mine and let you all know how I end up .)
VTKidder is offline   Reply With Quote
Old 08-21-2003, 03:53 PM   #8
rickspickuppart
I have heard of used car lots using atf and sometimes a water sprayer (squirt bottle) to break up carbon on real old motors but never to store one, but guess on a solid lifter motor it would coat the cylinders w/ oil in case one of the cylinders was stopped w/ a valve open, and it might prevent rusting but the cylinders would be hot enough to burn off any oil
Old 08-21-2003, 04:16 PM   #9
Fred T
Cantankerous Geezer
Fred T's Avatar
The ATF trick does work.
Here's what's recommended for engine storage.
Fresh oil and filter. Fresh antifreeze. Fill gas tank with your usual grade of gas, add stabilizer when you fill it. Driving it home will get it into the carb. Remove spark plugs, shoot a teaspoon engine oil into each cylinder, turn engine over a few times, then install plugs finger tight. (THis can be accomplished with the ATF). Remove the battery, and place it where it won't freeze, but not in contact with a concrete floor. Charge the battery monthly.
For the vehicle.
A cocoon is nice, but not always affordable. At the least, jack and block so the tires aren't on the ground. Put some moth balls in margerine tubs in the cab, along with some rat poison to keep out the critters. Tarp the cab if you can.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
