Old 08-21-2003, 10:53 AM   #1
swogee
Question Bench Seat Adjustment Rod Repair
I have a 1970 Chevrolet K10 with a bench seat, and the rod that that ties the two seat track adjusting mechanisms together has come unattached. It seems that the passenger side of the rod has a double 90 degree curve that fits into a hole on the adjustment mechanism but the driver side adjuster has a groove that the rod just sits on top of. Is there some sort of clip that holds the rod onto the seat adjuster groove? Also there are some metal links that are tied to the back of the lower seat frame that are not connected to anything. Do these connect to the center of the rod with a spring or some sort of linkage?
Thanks,
-Steve
swogee is offline   Reply With Quote
Old 08-21-2003, 12:15 PM   #2
jhow66
jhow66's Avatar
Hey Steve I will take me camera and get you a picture of it later this evening--check back.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-21-2003, 12:19 PM   #3
krue
Designated A-hole!
krue's Avatar
Welcome to the board!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-21-2003, 01:51 PM   #4
jhow66
jhow66's Avatar
Here you go. ( guess you can tell I am a "expert" photo taker)
Old 08-21-2003, 01:53 PM   #5
jhow66
jhow66's Avatar
#2
Old 08-21-2003, 02:07 PM   #6
swogee
jhow66,
Thanks for the pictures. Is there any way you can take a picture of the end of the crossover rod that connects to the driver side track latch? (I am talking about the rod that connects the driver side seat track latch to the passenger side seat track latch.) I can't figure out what holds the rod the onto latch mechanism. On the passenger side, there is a hole that the rod slips through, but on the driver side there is a finger or notch that the rod just rests in. It seems that there would be some sort of clip that holds the rod onto the seat track latch.
-Steve
Old 08-21-2003, 03:37 PM   #7
jhow66
jhow66's Avatar
Will do --give a couple of hours --just came in from mowing--92* & 68 yrs. young.
Old 08-21-2003, 05:17 PM   #8
jhow66
jhow66's Avatar
Sent PM with a couple of pictures
Old 08-21-2003, 05:20 PM   #9
jhow66
jhow66's Avatar
pictures
oops sorry forgot you were new--here they are:
Old 08-21-2003, 05:23 PM   #10
jhow66
jhow66's Avatar
other one:-- nothing holds it on but the way it is bent--also when you run it through loops it will stay put.
Old 08-21-2003, 10:54 PM   #11
swogee
jhow66,
Thanks for the pictures. I finally figured out what is missing on my seat. It looks like the spring and the clip and the end of the latch are missing. I didn't quite figure it out from the first set of pictures you posted.
Right now I have the rod butted up against the end of the latch mechanism (the "L" shaped part) and there is some wires wrapped around the two. Is there any chance you might know of a place that would sell the spring and the clip?
Thanks again for posting the pictures. They were a great help.
-Steve
Old 08-22-2003, 11:09 AM   #12
jhow66
jhow66's Avatar
Try junk yard--'73 up should be the same for awhile--Gm does not like to change anything if they don't have to. Good luck.
Old 08-26-2015, 12:03 AM   #13
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Bench Seat Adjustment Rod Repair
Just the ticket I was looking for.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-29-2021, 11:42 AM   #14
don t. - 72gmc
Old post but still helpful.
Found the rod, clip and spring on the floor when I moved the seat for a gas tank reline. Need to make some hangers for the rod.
Thanks much,
don t.
don t. - 72gmc is offline   Reply With Quote
Old 08-29-2021, 12:01 PM   #15
68bbc/20
I fixed mine with a piece of steel cable and crimped a loop on each end and a small turnbuckle to be able to adjust it with. a lot easier than the steel rod.
68bbc/20 is offline   Reply With Quote
Old 08-29-2021, 12:47 PM   #16
cj847
cj847's Avatar
easier than making one or searching the junk yard
https://www.carparts.com/details/Che...2030%20to%2035
cj847 is offline   Reply With Quote
