Old 08-20-2003, 01:03 PM   #1
81lwb350
big block lover
454 parts question for trucks!
wondering what you guys with a 454 in a 81-87 c/10 might be using for headers...what brand fits best..
also, did you have to change your front coil springs to compensate for the weight of the big block?
will the bell housing from a th350 that was bolted up to a 327 still fit the 454?
did you HAVE to change your fan shroud...seen alot of big blocks in el camino's that used the small block fan and shroud?
would i need a different fan clutch...
i all ready have my brackets! just these last few items are in question....goin to the parts yard this weekend!
81 custom deluxe lwb
454 bored .030 over w/ small RV cam.
2.5 exaust- thrush turbo muffs.
th350 getting beefed up soon!
81lwb350 is offline   Reply With Quote
Old 08-20-2003, 03:20 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I am going to use Sanderson BB3 coated headers (Chevelle application) becuase they don't hang down. I have used Heddman (cracked) but I don't want anything hanging below the frame.
You don't need new springs to compensate, what you have will work fine.
You can use a SBC fan shroud also, no difference. Same clutch fan should be ok, unless it is worn out/not working properly.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-20-2003, 05:59 PM   #3
81lwb350
big block lover
chris,
what headers are you using on your BBC?
im not lowered yet, but will probably do a 2/4 at least. maybe a little lower.
Old 08-20-2003, 06:18 PM   #4
44th Miss Inf
81lwb350,
I used DynoMax ceramic coated headers on my 81 w/454 that is lowered 5/5 with not problems.
And your bellhousing will bolt up with no problems.
Virgil
44th Miss Inf is offline   Reply With Quote
Old 08-20-2003, 07:22 PM   #5
81lwb350
big block lover
virgil,
do you have any pics of your truck?
Old 08-21-2003, 12:34 PM   #6
jimfulco
Be sure you use a flexplate with the counterweight for a 454. Get one with both converter-bolt patterns just in case.
jimfulco is offline   Reply With Quote
Old 08-21-2003, 01:45 PM   #7
Captkaos
Captkaos's Avatar
Originally posted by 81lwb350
chris,
Another words, these:
http://www.captkaoscustoms.com/images/sandersonhdrs.jpg
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 08-21-2003, 03:46 PM   #8
81lwb350
big block lover
44th Miss Inf
virgil,
are you using full length headers or shorties...
captC - those are sweet...could be a end to a future problem when lowering later...2/4 at first...maybe lower when its no longer going to be a daily driver. and $$$ permits...lol
thanks for all the tips so far guys!
Old 08-21-2003, 07:57 PM   #9
44th Miss Inf
Mine are full length. Never drug them and have never had a problem with them.
Virgil
