Old 10-30-2011, 09:06 PM   #801
big_al_71
big_al_71's Avatar
Re: Al's 71C10 Rebuild
Al,... in this picture,... you need to put the ECE bracket under the 2" block.
That will solve your problem.
You are the MAN!!!!!
Ok thats perfect that takes care of that issue. We took everything off but no biggie I will reinstall it tomorrow night........
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-30-2011, 09:14 PM   #802
raull
raull's Avatar
keith whatever you do, please stay on our build threads , yes putting the bracket under will work i didnt think of that , now keith on the blocks i told al maybe the one inch , the the two inch keeps the bags pretty full been that his diff hits the bed , what do you think ?
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 10-30-2011, 09:22 PM   #803
lolife99
67-72 parts collector,…
lolife99's Avatar
Hey Raull,... the "bag full",... but still dumped, means less volume of air to raise the truck.
(why go from 0-50 psi to raise the rear of your truck,... when you can go from 25-50 psi?)
Less run time on the compressor.
The bed floor is your limiting factor unless you cut it.
You also have a hat on top of the rear bag,... which I don't on my blazer.
(mine are bolted directly to the frame)
Like I said,... I like a low ride height.
I have a bumpstop in my notch to keep the rearend center section off the bed floor.
Which bums me out.
I'm still thinking about making a small hole in my bed floor so I can use all of the notch.
Keith
Convert to disc brakes.
Old 10-30-2011, 09:24 PM   #804
jmedero
jmedero's Avatar
check out this sway bar!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=444390
Al I think I might have some of that porterbuilt rear stuff. Let me know if your interested.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 10-30-2011, 09:29 PM   #805
raull
raull's Avatar
lol lowering sickness , thats what i told al to do a mini tub in the center of bed , ok we'll put the bar bracket at bottom blocks and adjust it .
raul
Old 10-30-2011, 09:41 PM   #806
jmedero
jmedero's Avatar
Keith is awesome!! You helped me figure out that my inner rods were on backwards. Your like the yoda of 67-72 trucks!! Lol
Old 10-30-2011, 09:44 PM   #807
big_al_71
big_al_71's Avatar
so true!!!!!!
Juan I like that swaybar from scottshotrods
i will get with you about the porterbuilt stuf if I need it...
Thanks bro..
Old 10-30-2011, 10:18 PM   #808
RocketKing
RocketKing's Avatar
Gotta agree that lolife99 knows his stuff, especially on wheels, I have PMed him so much about backspacing and rims I am surprised he hasn't blocked me yet. lol
Rex
RocketKing is offline   Reply With Quote
Old 10-30-2011, 10:52 PM   #809
Bennett68C10
Bennett68C10's Avatar
Al on my 72 my rear hit the bed without the blocks but I also had my rear bags bolted on without plates. I agree with lolife99, I would keep the 2" blocks so the bags are more full when you air it out.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-30-2011, 10:56 PM   #810
lolife99
lolife99's Avatar
This is the backspacing I like up front.
This is n2billet's '68,... aka Lucy.
These are 20x8.5 Billet Specialties softlip Vintec's with 5.75" BS.
This (in my opinion) the perfect front bs for a mild non-Dropmembered bagged truck.
Just plates and cups.
Nate's truck (72BlckButy's) has a 20x8.5 with a 5.5" BS.
Perfect for a static dropped truck.
Both of these trucks have different rear backspace numbers.
Both have the narrower 67-69 rearend.
But n2billet's truck has had the outer wheelhouse of the bed modified for the least amount of backspacing.
Al's truck has the wider 71-72 housing.
(1.5" wider on the total width dimension)
I would run a 20x10 with a 5.5" BS on a "mild" bagged truck with a 71-72 rearend.
(and a 20x10 with a 5" BS on a "mild" bagged truck with the early narrower 67-69 rearend)
These are my numbers,... that I like.
I still tell everyone to measure their own truck, to make sure.
Just remember that a 20x10 will actually measure 11" wide.
(20x8.5 will measure 9.5" wide)
Keith
Old 10-31-2011, 07:42 AM   #811
big_al_71
big_al_71's Avatar
I am right there with you...
thanks for the advice I truly appreciate it fellowes!!!!!!
Old 10-31-2011, 07:43 AM   #812
big_al_71
big_al_71's Avatar
Keith thank you for taking the time to clear all the things for me I now have a more clear understanding......
Wheel choice time!!!!
Albert
Old 10-31-2011, 11:34 AM   #813
1stchevy
1stchevy's Avatar
Bonspeed quicksilvers
1stchevy is offline   Reply With Quote
Old 10-31-2011, 01:05 PM   #814
big_al_71
big_al_71's Avatar
Cool looking wheel... thanks
Old 11-01-2011, 09:41 PM   #815
big_al_71
big_al_71's Avatar
I decided to go with th hiboy billet specialties....now time to just get this truck buttoned up so by the time the wheels get here we will be ready to hit the road.....
Old 11-01-2011, 09:54 PM   #816
lolife99
lolife99's Avatar
Excellent choice!
Keith
Old 11-01-2011, 09:57 PM   #817
big_al_71
big_al_71's Avatar
Excellent choice!
Thanks for all your help...I cant wait to seeing them installed on my bucket....
Old 11-01-2011, 10:53 PM   #818
Bennett68C10
Nice wheel choice, I'm excited to see them they are going to make your truck look great
Keith
66 Suburban
IG: bennett68c10
Old 11-02-2011, 08:10 AM   #819
JWall
Frequent Flyer
JWall's Avatar
No pics yet of the wheels on yet???
Good choice I can't wait to see it all finished.
- Justin
1 Owner 1976 SWB
Old 11-02-2011, 08:42 AM   #820
big_al_71
big_al_71's Avatar
For sure brother
Hahahaha ok there Justin rub it in
Old 11-03-2011, 12:38 PM   #821
big_al_71
big_al_71's Avatar
We put about an hour and a half last night. We reinstalled the two inch blocks, rear panhard bar, installed the new brakes hoses with brake lines on all four corners, installed the new front sway bar from (Ride tech). We are getting ready to install the compressor, air tank and do the electrical connections with the E3 leveling sensors in the next few days. We are taking our time and working on the truck bits at a times since we have no wheels anyways.
Old 11-03-2011, 12:46 PM   #822
1stchevy
1stchevy's Avatar
I know your ready to see this thing aired out on billets, it's going to look killer.
Old 11-03-2011, 12:50 PM   #823
jmedero
jmedero's Avatar
I like how you say taking our time..... You've been flying through this. Some of us are two years deep amd no were near this. Lol
Old 11-03-2011, 12:53 PM   #824
VA72C10
VA72C10
VA72C10's Avatar
nice progress....and we're all excited to see this thing aired out on billets
Old 11-03-2011, 12:56 PM   #825
67cheby
67cheby
67cheby's Avatar
yep, what they said
67cheby is offline   Reply With Quote
