Old 10-29-2011, 10:17 PM   #1
firemanmario
firemanmario's Avatar
clamshell mounts
I got the clamshell tower's, mounts and a 1.250 swaybar from my local yard. Started the install today. You can see the mounting location for the original tower here.
firemanmario is offline   Reply With Quote
Old 10-29-2011, 10:22 PM   #2
firemanmario
Re: clamshell mounts
I was able to elongate the upper holes in the towers to get them to bolt up to the upper mounting location and was able to line up the rear hole on the bottom.
Old 10-29-2011, 10:27 PM   #3
firemanmario
Drilled out the front hole for the bolts and set the mounts in loosely. Will be working on setting motor in tomorrow and seeing where the engine and trans ends up in relation to the stock location.
Old 10-30-2011, 10:59 PM   #4
firemanmario
I got the motor and trans in place today. There's plenty of room and seems to be about 1 1/2" further back which is fine by me. I haven't decided if I'm gonna fab a newer trans mount or just drill some holes. That pretty much covers the clamshells. They fit with very little mods. Will still need to take a look at driveshaft length.
Old 10-31-2011, 12:12 AM   #5
MusicMan70
MusicMan70's Avatar
Nicely Done mario, Bravo!
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 10-31-2011, 01:18 AM   #6
firemanmario
Thanks, I've still got a lot of work ahead.
Old 10-31-2011, 09:47 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Very nice! Much better mount design and more room for exhaust. Win-win
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-31-2011, 10:51 AM   #8
firemanmario
Thanks Gringo, I'll probably be getting tips from your thread too. Looks like you've got a lot done on your ride. My truck is a C20 camper special that I'm gonna try and do some of the same things........If only I had more time in the day.
Old 04-05-2012, 03:10 PM   #9
firemanmario
ok, so it's been a while since I posted last. Got some headers at the local meet for $60 that sit a little below the bottom of frame, but would run right into the original trans mount.....so I made a new one. Used the existing holes on the frame and this will be modified again later as I will be putting in a 700r once I've got it on the road. The driveshaft will need to be shortened about 2 inches as well. On the plus side the mount was made with a bunch of scrap I had from other projects.
Old 04-05-2012, 03:24 PM   #10
firemanmario
here's the progress on the engine as well
Old 04-05-2012, 07:11 PM   #11
firemanmario
here's a few with the exhaust in place. As I get some time the exhaust will be routed thru the trailing arm cross member.
