Old 10-31-2011, 10:33 AM   #1
Joe Blaze
Recommended gear oil '71 4WD Blazer
I wanted to check the fluids before the winter on my '71 Blazer 4WD. Can anyone advise what are the modern day equivalents of the recommended front and rear end gear oil, and the transfer case fluid? I would be topping off, not changing out fluid.
Joe Blaze is offline   Reply With Quote
Old 10-31-2011, 12:51 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: Recommended gear oil '71 4WD Blazer
I would put 80W-90 In all of them with maybe a quart of ATF in the transmission/T-case for extremely cold weather.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 10-31-2011, 01:41 PM   #3
mrein3
mrein3's Avatar
I agree on the diffs. 80w-90. Make sure you don't have posi. If you do you'll need to add some friction additive.
The stock transfer case should be a NP205. I've seen GM specs for that unit that specify 80w-90 and Automatic Transmission Fluid (ATF). Nothing changed, just the spec printed by GM.
I've been running ATF because it works better when its -20 fahrenheit and you need to push the snow off the driveway.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-31-2011, 02:20 PM   #4
Joe Blaze
Would it make a difference if I have automatic transmission?
Old 10-31-2011, 03:13 PM   #5
Joe Blaze
How would I be able to tell if I have posi?
