Old 10-26-2011, 10:39 PM   #1
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Help on my "88 when its cold first start my truck smells rich wants to backfire?
So thought I had fixed this problem last spring but apparently not. With it getting cold at nights now when I first start it in the mornings wants to run ruff and backfire a few times then will idle normally. Anytime later on in the day I start it runs just completely perfect. Smells rich so to much fuel I am guessing is the problem. I put new plugs in last spring and new coolant sensor front of the intake on. Also put a new IAC motor on the TBI unit. I recently tightened up the headers and put TBI cleaner through it to clean it up. So I know the timings on cause we did that as well last spring. Would having weak back pressure on the exhaust or injectors going bad do this? Any input or help would be greatly appreciated I am at the end of my rope with it haha! Its an '88 chevy 350 TBI 5 speed 4x4 2500
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Last edited by Hoods69BadBowTie; 10-26-2011 at 10:42 PM. Reason: Add vehicle info to post
Hoods69BadBowTie is offline   Reply With Quote
Old 10-27-2011, 07:31 PM   #2
gregory5000
Re: Help on my "88 when its cold first start my truck smells rich wants to backfire?
Does this model year have a Mass Air Flow sensor? I work at a engine plant and our test benches do that when the MAF sensor is dirty.
2001 GMC 2WD, 1998 Chevy K2500
gregory5000 is offline   Reply With Quote
Old 10-30-2011, 07:54 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
No MAF sensor that I know of. Thanks though I got asked that by a few people already. I did a new o2 sensor didn't fix anything.
-LATER
Old 11-01-2011, 03:31 PM   #4
Rod_Lei
Does yours have the smog pump?
I could be the Air Injection Reaction System.
AIR valve will throw extra air into the exhaust to make the computer add more gas to warm up the vehicle, it's supposed to close at operating temp, but mine quit doing that. I just eliminated the system.
A thought...
Rod_Lei is offline   Reply With Quote
Old 11-01-2011, 04:39 PM   #5
speedygonzales
speedygonzales's Avatar
Air is put into the exhaust at start up to heat up the cats faster. The ECM ignores the O2s at start up and goes to an enrichment table to warm the engine up. After reaching a predetermined temperature, the system goes into closed loop and refers to among other things, the O2s.
My money is on a leaking gasket that seals up as temperature rises. More precisely the 2 surfaces that are sealed by the gasket are expanding and sealing the gasket surface.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
