Old 11-02-2011, 09:58 AM   #1
FL71C10
Re: 250 i6 fuel economy w/o sacrificing HP
I would think the 5 speed transmission would help make up for the lower rear end gear ratio.
Originally Posted by longbed67 View Post
Get yourself a wideband and look at your #'s the 3.07 is to low of a ratio for the h- power and torque curve of a stock 250, thus you must put more foot into the throttle, thus richening the mix and killing fuel economy. I drove through the mountains with a 3.73 and a stock 250 and got 17+ all day long on my trip back from washington. If you want to keep the 3.07 you can but do a cam change, headers, clifford intake, holley 4bbl carb (get it tuned properly), and an hei ignition and you will have about 75-100 more hp and ftlbs torque and you have better fuel econ. visit www.12bolt.com, tom has a lot of info and products at very good prices that will help you out on the 250.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 11-02-2011, 10:16 AM   #2
longbed67
longbed67's Avatar
Never thought to ask is the 15 MPG in town or highway? if your going into 5th gear on the highway with the OD .73:1 gear your going to throttle harder than if you kept it in 4th with the straight drive 1:1 gear. If it is in town... Get a proper tune on the carb jetting and ignition timing, and stay out of the throttle...
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
