Old 11-01-2011, 08:46 PM   #1
Evil Trailblazer SS
Big Gulps Huh? Whelp...
Evil Trailblazer SS's Avatar
Dash Cluster Question - Separate Light W/Leads
So I feel like a moron because I usually make sure to document or photograph everything as I disassemble, but I screwed up yesterday.
In removing the gauge cluster from my '87 V30 and this little light bulb was plugged into one of the dash warning locations, I am thinking it was the SES light, but I honestly have no clue. It is the only light on its own wire leads (not part of the printed circuit wiring.
Can anyone help me find this little light's home?
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
Evil Trailblazer SS is offline   Reply With Quote
Old 11-02-2011, 12:59 AM   #2
beamn7
Re: Dash Cluster Question - Separate Light W/Leads
Pretty sure you are right. My 85 has the same thing....
beamn7 is offline   Reply With Quote
Old 11-02-2011, 01:29 AM   #3
TheApocalyptican
TheApocalyptican's Avatar
Is it maybe the 4x4 light? I know in my Sub, the SES is NOT separately wired, and I thought the 4x4 one was the one with separate wiring.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 11-02-2011, 02:30 AM   #4
beamn7
Lightbulb Re: Dash Cluster Question - Separate Light W/Leads
That's a good point. It would only be the SES light if you have a seperate indicator between the speedo and fuel gauge at the top of the bezel.... I don't believe the R/V series had that. Pretty sure it was added into the cluster at that point....
Old 11-02-2011, 07:55 AM   #5
b454rat
Think it's the 4wd indicator.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-02-2011, 10:07 AM   #6
48cj2a
48cj2a's Avatar
Not disagreeing with those that posted but my factory wiring manual says the 4wd indictor lamp circuit has a black and a white wire coming off the T/C switch. Black to the 6 terminal grd buss and white to the bulb socket. The black wire from the bulb socket goes to a "B" hot in accsy start and run in the upper fuse block.
Upon going over the ECM Outputs page it shows a PNK/BLK coming from the Check Engine Lamp Driver Connector with a splice going to the Check Engine Eng LP - but it does not show a lamp on the page.
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 11-02-2011, 10:55 AM   #7
Telecasterjoey
Put her in 4X4 and see if she lights up!
Telecasterjoey is offline   Reply With Quote
Old 11-02-2011, 10:57 AM   #8
Evil Trailblazer SS
The SES indicator is in the same spot as the older "Choke" indicator. The goofy thing is, all bulb sockets on the cluster have leads on the printed circuit but this stupid little light still remains.
I did test it by putting the truck into 4WD and the bulb did not activate. I will continue testing once I get the new radiator installed...
Thank you for the responses so far everyone!
Old 11-02-2011, 04:15 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
it's for the 4X4
i have both my 79 and 88 in front of me and the only socket empty is the 4X4 both
but just check the main harness plug,doubt there would be "wires"leading to the copper path to that spot
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 11-02-2011, 05:01 PM   #10
Evil Trailblazer SS
Weird thing is, I've traced all circuits on the copper board and both the SES and the 4WD have leads...there is not dead plugs in the cluster..
Old 11-02-2011, 06:48 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
SES would light when starting, 4X4 won't tho
and my SES light hole is yellower then the 4X4
John
Old 11-02-2011, 08:59 PM   #12
flamingbig10
6.0 powered square
flamingbig10's Avatar
turn your dash lights on and see what happens
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
