Old 08-21-2003, 08:50 AM   #1
Durney
For you 4WD guys.....
I am close to assembling the 700R4 NP205 setup into the 67' 3/4 ton. The 205 is from a 75' and does NOT have the mounting holes in the end of the case to accomodate the L-bracket that my T221 used.
I have spoken with several 4WD "enthusiasts" locally and one professional and they all seem to agree that it is unnessesary and most of the late trucks with the 205 only were supported by the trans to case adapter. Which explains the lack of mounting holes.
I obviously have the facilities to machine it correctly,but is it necessary for a vehicle that see's very limited "abuse"?
Durney is offline   Reply With Quote
Old 08-21-2003, 09:44 AM   #2
Yukon Jack
Yukon Jack's Avatar
They are so heavy that if I had the ability, I'd machine it and add some support. Maybe it's not necessary, I don't know, but would give peace of mind.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-21-2003, 09:52 AM   #3
Durney
Agreed Jack and I most likely will but I was looking for someone who has the non-supported setup for definitive feedback.
thanks for the answer!
Old 08-21-2003, 11:00 AM   #4
Mark540
Tough question because I believe all 205's in our era of truck were bolted to the frame.
1970 GMC Burb 4x4 - 68 Chevy Front, FI LT1, 4L60E
1970 Chevy Impala 47,000 miles
2001 BMW 540i 6-speed
2002 Dodge Ram 1500 4x4 w/20's
Mark540 is offline   Reply With Quote
Old 08-21-2003, 11:13 AM   #5
Durney
Correct, that much we know. But obviously Chevrolet decided at one point that the side support was no longer necessary. So the question stands....who's running without one in our trucks? ( or other trucks)
Old 08-21-2003, 11:42 AM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Actually, I have heard a lot of guys (on ColoradoK5.com) that don't have the extra bracket. My understanding was that that was hit or miss on the NP205. The NP203 had some long rods that connected to the transmission for extra support. I have also seen some NP205s (not sure what truck they were in) with 2 cross members. One under the adapter and one under the rear of the t-case.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-21-2003, 01:19 PM   #7
Pont
I need another Barley Pop
Pont's Avatar
Well, I wish I could give you the answer you're looking for, but I can't. My 205 t-case came out of a 78 and was not drilled for the torque mount either but I drilled and tapped it before it went into my 67. As Yukon said, that's a lot of weight hanging out the back, that extra support gives me piece of mind. The stories I have heard about broken t-case adapters is what motivated me to hang the torque mount.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 08-21-2003, 01:48 PM   #8
landon4421
Life is Good !
landon4421's Avatar
make the arangements to put that support bracket to the frame an your truck, I took mine off once and went out puddle jumping, the transmisson and t-case bounced around under there, I looked to see if anything else was loose and evrything was tite. After putting the bracket back on it stoped hoping around. Just my .02 cents. Landon
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 08-21-2003, 08:55 PM   #9
JimKshortstep4x4
Smile
There is a definite benefit to having the side support in place if you have to pull the engine. The transmission is nicely supported!
We would not run without the support in our (6) 4x4's as I agree with Jack on the weight. We also had a truck without the brace in place and the transfer case moved when pulling trailers, (not a lot).
Jim
Old 08-21-2003, 09:37 PM   #10
Blue_71
Bloo
Blue_71's Avatar
anyone got a pic of this? i dont think my truck has it (you can feel hoping sometimes when in a hard pull, i thought maybe bad bushings)
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 08-21-2003, 11:35 PM   #11
Rod
Hmmmmmmm my spare NP 205 TC from a 75 with automatic has the side bracket holes. Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
